Plugins for S3L, 32bit vs 64bit?
I'm a bit confused what plugins can we use on our sparkling new consoles. I assumed they just must be AAX DSP but what about the bits? Are 32 bit and 64 bit plugins different? If the system runs 32 bit plugins does that mean that if a plugin is 64 bit I can't use it? Some clarification would be good.
Re: Plugins for S3L, 32bit vs 64bit?
Hi Kristo,
The plug-ins that ship with the system are currently 32-bit. We'll be qualifying more plug-ins from Avid and other developers as time goes on. Sheldon |
Thanks Sheldon. This rises another question, as you talk about plugins that ship with the system.. does that mean we are no longer able to exit to desktop and install third party plugins ourselves?
With S3L, you're still able to exit to desktop and install PIs - as usual.
btw, DVI to VGA does not work with S3L for some reason. So your screen needs to have DVI! |
Hi guys,
I strongly recommend you do NOT manually install plug-ins that are not qualified with S3L. It's likely that some plug-ins will not work as expected until they've been through the qualification process. It's not worth risking your reputation or a show on an untested setup. Sheldon |
Hi Kristo,
Better safe than sorry. Plug-ins will be added to the main plug-in finder here: http://www.avid.com/plugins Choose the "AAX VENUE" filter to see what's been officially qualified. Sheldon |
DVI on S3L is DVI-D, i.e. digital-only. So DVI-to-VGA converters won't work.
So, has someone got some plugins running on S3L in addition to what it comes with?
Avid, please hurry up! We are missing some basic stuff like D-Verb, Smack!, PSA-1 but it would make sense to see all the VENUEPack4 plugins running on the new desk. |
32bit Expansion Chassis on win7 64bit | Diggerthedogboy | Pro Tools TDM Systems (Win) | 8 | 03-04-2013 08:22 AM |
32bit or 64bit?? | Codo | Pro Tools TDM Systems (Mac) | 3 | 03-02-2012 03:14 AM |
32bit PTS plugins will it run on Win & 64bit? | andre67 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-12-2010 07:41 AM |
002R will it run 32bit 7.4 and 64bit 8.0.3 both? | aka21stCentury | General Discussion | 3 | 06-12-2010 11:36 AM |
going from 64bit to 32bit | sterndrup | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 30 | 12-11-2008 10:12 AM |
