frustration
Hi, just want to shout out my frustration about Pro Tools . I run Pro Tools 12.5 on Windows 8.1 and there are a few things there are really annoying.
First if I wanna close Pro Tools the program never reacts to that and I always have to force it to quit. Secound the Audio Suite Gain doesn´t analyze sometimes. Its just random if its analyzing the gain or not. Same problem with bouncing a clip (shift+strg+k). Sometimes it works and sometimes just not. Had exactly the same problems with PT 12.3 and nothing changed with the new version. I know these are just small issues, but it really interrupt the workflow if it occurs very often. And thats the case. I really really hope they will fix these issues. cheers David |
Re: frustration
Have you reported these issues at protools.ideascale.com? Have you opened a support case with Avid about any of these issues?
Re: frustration
Are you sure, that there is no uncleared search in the clip list and that "show auto-created" is checked ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Re: frustration
When it is not analyzing, do you get the message "No audio was selected" ?
Re: frustration
Hi thanks for your reply. No haven´t done it yet. Will do that thanks.
@joachim: I selected an audio clip and this message didnt show up. Sometimes the value is absolutely wrong or doesn´t even change from the prior clip value. After some clicks on the analyze button it can happen that it works again, sometimes it doesn´t help. And sometimes it works again on the whole clip if I first make a selection within the clip and click at analyze. (so analyzing value on whole clip seems to be not right, make a selection and analyze and after that on the whole clip again and value is different) makes absolutely no sence for me but ok. And the problem with bouncing a clip is that the key combination (shift+strg+k) sometimes doesn´t work. If thats the case I have to double click on the clip, copy the name, search in the cliplist and with right mouse button export media. But that´s not that annoying like the way that audio suit gain works^^ |
Re: frustration
Weird.
My assumptions were wrong. Maybe a repair-install could help.
Re: frustration
So you are also running PT12.5 on Windows 8.1? If not, starting a new thread with all of your current system details will be more likely to bring the help you are seeking.
I/O frustration | Goldencd | Pro Tools 9 | 6 | 03-22-2011 10:03 AM |
Frustration! | Herrington | Pro Tools 9 | 3 | 03-01-2011 09:12 AM |
Frustration | lcollen1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-29-2008 04:02 AM |
OSX Frustration!!!!!!!!!!!!!!Help!!!!!!!! | EarnestBliss | Tips & Tricks | 4 | 10-28-2003 11:24 AM |
agh! Frustration!! | pfd4 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-13-2003 09:15 AM |
