Old 05-04-2015, 09:53 AM
SteveGarman SteveGarman is offline
Default Playback web audio and record it in PT at the same time?
I need to playback some web based audio and record it at the same time in PT or some other audio app at the same time. I have a Mac pro. Would I just jack the line out into the line in on the back of the Mac? How else could this work?
Thanks,
Steve
Old 05-04-2015, 09:55 AM
Drew Mazurek's Avatar
Default Re: Playback web audio and record it in PT at the same time?
If you can do it digitally that would obviously be ideal. I do this all the time with an optical cable.
www.drewmazurek.com
Old 05-04-2015, 10:00 AM
Meads Meads is offline
You could also do it without cables using Soundflower or Source Nexus.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 05-04-2015, 11:19 AM
How would you hook this up? What would you select in PT?
Old 05-07-2015, 07:58 AM
Benoni's Avatar
Benoni Benoni is offline
Just wondering, why do you need to record the audio from the web into PT? Why not just download the file and import it?
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 05-07-2015, 03:45 PM
Ben Jenssen's Avatar
Capture live internet streaming audio...
There was an application called Audiohijack to do exactly this...
Old 05-07-2015, 04:35 PM
Carl Kolchak Carl Kolchak is offline
Can you believe the Audacity of some people
Great for file format conversions, amongst other things.
Old 05-08-2015, 06:49 AM
Benoni's Avatar
Not what I meant. There are plenty of reason to capture a stream either video or audio from the web, I do it all the time for live streamed events. I was just wondering exactly what the OP was trying to do because there are other options available if the event is pre-recorded vs. live.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Playback and record not working at same time ljones macOS 0 10-17-2012 05:38 PM
no audio playback when track is record enabled indoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-05-2008 06:02 AM
Strange Playback/Record Audio Situation - Need Help Please JCWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-26-2007 10:26 AM
long record time and no audio in the file? zero-dB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-23-2005 10:35 AM
Record/playback at the same time TRK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-28-2001 11:50 AM
