Re: no audio
Can you tell me at what resolution I can post picture here?
Re: no audio
[QUOTE=Omar08;2426291]
Can you follow the instructions for posting a Sandra Report, under the "Help Us Help You" link on every DUC page. Copy and past the text from that report here, nobody asked for or wants an unreadable screenshot. There are many thousands of correct useful Sandra posts on DUC, search for some if those and post the exact same as those posts. Sent from my iPhone using Tapatalk |
Re: no audio
[QUOTE=Darryl Ramm;2426365]
ID Host Name : Dell Workgroup : WORKGROUP Computer Model : Dell XPS 8900 Serial Number : CZ8**** Chassis : Dell Desktop Mainboard : Dell 0XJ8C4 Serial Number : /CZ89482/CN7************ BIOS : Dell 2.1.0 11/12/2015 Intel vPro : 11.00.00.1183 Total Memory : 16GB DIMM DDR4 Processors Processor : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz (4C 8T 3.91GHz, 3.9GHz IMC, 4x 256kB L2, 8MB L3) Socket/Slot : FC LGA1151 Chipset Memory Controller : Dell Core (Skylake-D QC) Host Bridge/DRAM Registers 100MHz, 2x 8GB DIMM DDR4 2.13GHz 128-bit Memory Module(s) Memory Module : Hynix (Hyundai) HMA41GU6AFR8N-TF 8GB DDR4 PC4-17100U DDR4-2132 (15-15-15-37 4-52-17-6) Memory Module : Hynix (Hyundai) HMA41GU6AFR8N-TF 8GB DDR4 PC4-17100U DDR4-2132 (15-15-15-37 4-52-17-6) Video System Monitor/Panel : AOC International 2436 (1920x1080, 23.4") Video Adapter : NVIDIA GeForce GTX 745 (3CU 384SP SM5.0 1GHz, 2MB L2, 4GB 1.8GHz 128-bit, PCIe 3.00 x16) Graphics Processor CUDA GP Processor : NVIDIA GeForce GTX 745 (384SP 3C 1GHz, 2MB L2, 4GB 1.8GHz 128-bit) OpenCL GP Processor : NVIDIA GeForce GTX 745 (384SP 3C 1GHz, 48kB L2, 4GB 1.8GHz 128-bit) Compute Shader Processor : NVIDIA GeForce GTX 745 (384SP 3C 1GHz, 2MB L2, 4GB 1.8GHz 128-bit) OpenGL Processor : GeForce GTX 745/PCIe/SSE2 (4GB) Storage Devices WDC WD3200AAJS-56M0A0 (320.1GB, SATA300, 3.5", 7200rpm, 8MB Cache) : 298GB (C:) Seagate ST2000DM001-1ER164 (2TB, SATA600, 3.5", 7200rpm) : 2TB (G:) WDC WD10EZEX-08WN4A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (F:) Compact Flash (USB2/NVMe) : N/A (H:) SD/MMC (USB2/NVMe) : N/A (M:) MS/MS-PRO (USB2/NVMe) : N/A (J:) xD-Picture (USB2/NVMe) : N/A (K:) TSSTcorp DVD+/-RW SH-216DB (SATA150, DVD+-RW, CD-RW) : N/A (D:) ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) : N/A (E:) Logical Storage Devices WIN7 (C:) : 260GB (NTFS, 4kB) @ WDC WD3200AAJS-56M0A0 (320.1GB, SATA300, 3.5", 7200rpm, 8MB Cache) AUDIO (F:) : 932GB (NTFS, 4kB) @ WDC WD10EZEX-08WN4A0 (1TB, SATA600, 3.5", 7200rpm) 2 TB (G:) : 2TB (NTFS, 4kB) @ Seagate ST2000DM001-1ER164 (2TB, SATA600, 3.5", 7200rpm) Hard Disk : 16GB (NTFS, 4kB) @ WDC WD3200AAJS-56M0A0 (320.1GB, SATA300, 3.5", 7200rpm, 8MB Cache) RECOVERY : 12GB (NTFS, 4kB) @ Seagate ST2000DM001-1ER164 (2TB, SATA600, 3.5", 7200rpm) Removable Drive (H:) : N/A @ Compact Flash (USB2/NVMe) Removable Drive (M:) : N/A @ SD/MMC (USB2/NVMe) Removable Drive (J:) : N/A @ MS/MS-PRO (USB2/NVMe) Removable Drive (K:) : N/A @ xD-Picture (USB2/NVMe) Optical Drive (D:) : N/A @ TSSTcorp DVD+/-RW SH-216DB (SATA150, DVD+-RW, CD-RW) Optical Drive (E:) : N/A @ ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) Peripherals LPC Hub Controller 1 : Dell Z170 Sunrise Point-H LPC Controller Audio Device : Dell Sunrise Point-H HD Audio Audio Device : nVidia High Definition Audio Controller Audio Codec : nVidia nForce2 ISA Bridge Disk Controller : Dell ICH8R (ICH8) SATA RAID Controller Disk Controller : Dell Sunrise Point-H PMC USB Controller 1 : Dell Sunrise Point-H USB 3.0 xHCI Controller FireWire/1394 Controller 1 : 22785 FW643 PCI Express1394b Controller (PHY/Link) SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Send to Microsoft OneNote 16 Driver (1200x1200, Colour) Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Printer : Microsoft Print To PDF (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Canon MG2900 series Printer XPS (USB, Colour) Peripherals Network Services Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet) Network Adapter : Intel(R) Ethernet Connection (2) I219-V (Ethernet) Wireless Adapter : Dell Wireless 1801 802.11b/g/n (802.11n (HT), AES-CCMP, 72Mbps) Operating System Windows System : Microsoft Windows 10 Personal 10.00.10586 Platform Compliance : x64 Performance Enhancing Tips Warning 2513 : TPM not detected. Some security features are unavailable. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Re: no audio
Really not sure. I post screenshot here and they are so small while perfectly clear and big on my monitor.
Re: no audio
There is no obvious problem showing up with you Sandra report, and now we all know what computer you are in.
The Win 7 partition I am assuming you upgraded to Windows 10 and that is the partition you booted from right? --- So now what exactly are you doing? What monitors are the Saffire connected to? via what exact cables. What is the playback engine selected in Pro Tools? (Setup>Playback Engine). Edit: Your earlier screenshot shows Saffire, so that's good. What are all the options shown under the playback engine pulldown? What exactly happens? You are trying to play back prerecorded content or you are trying to track something? The transport appears to go into play and you hear nothing? Track and master fader meters in Pro Tools all move Pro Tool and you hear nothing? What exact driver version for your interface did you install? Is all this new to you? Pro Tools? Working with that interface and it's control panel? Does this session play elsewhere? One of the screenshots looks like you have all or at least a few VI tracks. You should start with a simple session with known good simple audio tracks... have you tried that? What standard troubleshooting have you tried.... Things like: Do you hear anything via the computer speakers if you select the PC audio as a playback engine? (to do that you need to either have an ASIO compatible sound card or ASIO4ALL installed on the PC, often worth doing as a test). If you close Pro Tools and select the interface as the Windows sound device do you hear Windows sounds and other apps through the interface? Trash Pro Tools prefs Test with headphones connected to the interface. Test with the a new simple session. Create an empty session, one stereo audio track and drag and drop a known good MP3 or similar file to that track. No master fader, no bussing nothing else. Press play. Do you hear anything out the interface? Track meters move? Posting screen shots of the Saffire control etc. may help. You can attach fairly large screenshots using the paperclip tool. Just trim the image down to the control window part and post that at full resolution. Last edited by Darryl Ramm; 05-07-2017 at 03:43 PM. |
#16
Re: no audio
No audio i want to a few details about what is the decision of pics in Pixel
assignment writing services |
#17
Re: no audio
#18
Re: no audio
Hey I am not able to Download this PDF. PLease Help
Greenify Donation APK |
#19
Re: no audio
is the pdf file is empty its not showing in my computer
Free Custom Essays Online |
#20
Re: no audio
You have to click on the file then it will download to your computer and you open it in Adobe Reader.
Importing audio files for remix - convert or set session to match source audio? | LSW | Tips & Tricks | 22 | 09-09-2014 09:28 PM |
Audio Suite process puts new audio in audio bin | Fritz12534 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-21-2009 08:55 AM |
PRO TOOLS giving 2 Audio track ''Audio 5_02.L and Audio 5_02.R'' | fredson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-20-2008 09:08 AM |
How can I bounce mutliple audio/instrument tracks as mono Audio files in ProTools LE | thaprof | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-16-2008 11:03 AM |
USB2 Audio HD vs Fw Audio HD vs internal audio HD | seth666 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 07-07-2005 02:06 AM |
