Old 03-23-2017, 12:02 PM
reichman's Avatar
reichman reichman is offline
Default Application Switch - Mixer View BUG
EuCon 3.5, PTHD 12.7.1, macOS Sierra 10.12.3:
When I command-tab to another application (SoundMiner, RX, etc.) while PT|Control is in Mixer view, when I go back to PT, the view snaps back to the first 8 tracks. This feels like a bug, because you don't see that behavior in Tracks, Channel or Soft Keys view.
Thanks for reading Eddie! This is probably on Ideascale, but if not, I can add it.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 03-27-2017, 01:44 PM
EddieJones's Avatar
Default Re: Application Switch - Mixer View BUG
I'm not seeing this here, can you make sure you have PT locked to the surface too and see if that makes a difference ?
Old 03-27-2017, 06:16 PM
reichman's Avatar
PT is locked. I run into this now 40% of the time. What happens is this behavior sticks for a while (10 or so application switches) and then goes back to normal. I'll look more closely to get you the exact steps to recreate. Thanks Eddie.
Nathaniel Reichman
Old 04-21-2017, 08:45 AM
spoons's Avatar
spoons spoons is offline
I am seeing this too.
Richard Spooner
Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM.
www.spoonsound.com
Old 04-21-2017, 01:51 PM
EddieJones's Avatar
Can you guys make sure you do this if on a Mac Clean Eucon Script
Or Uninstall and Reinstall if on Windows.
Old 04-26-2017, 01:39 AM
spoons's Avatar
I've done a clean install and this still happens.
Richard Spooner
www.spoonsound.com
Old 04-26-2017, 06:35 PM
reichman's Avatar
Same here. Followed Eddie's instructions and put EuCon 3.6 in, Mixer view still jumps when switching applications. And I'm locked to PT. Weird.
Nathaniel Reichman
Old 07-10-2017, 04:12 PM
reichman's Avatar
Fixed in Eucon 3.6.1! Thanks Eddie. It's the little things that count...
Nathaniel Reichman
Pro Tools hangs after every application switch legasafe Post - Surround - Video 16 08-20-2015 02:26 AM
Application Manager Bait and Switch Sonny Keyes Pro Tools 11 3 06-15-2015 11:34 AM
How can I keep my mixer view in view? Sam C macOS 14 05-16-2013 02:16 PM
Application switch key and shift layer aptmusic9 Artist Series 0 05-04-2012 04:10 PM
Switch a track to playlist view from D-Command bvirkler ICON & C|24 6 01-12-2011 08:06 AM
