Old 08-12-2003, 02:21 AM
Impala Impala is offline
Default O.T. Glyph Firewire doesn\'t unmount
I just installed a new Western Digital WD800 disk in my Glyph 1U Firewire rack. I initialized the disk using "Glyph Audio Storage Toolkit"s auto initialize function and everything seemed to run o.k.
There's no problem copying files and reading back but when I drop the disk icon in trash and shut down Glyph, Mac says "A firewire disk has stopped responding...." thing.
What's weird is when I trash the original Glyph drives (which are IBMs) i hear a harddrive 'head parking' noise. There's no noise with Westerns.
(I also tried another -non Glyph- IBM and it was also ok)
Though the disk runs o.k. I need to solve this issue. Any recommendations are appreciated.
HD3 + Control 24 + 2 192s
Mac Pro 12 core 2.93 & PT 8
16 Gig RAM
Glyph Firewires
Motu MTP AV USB
Old 08-12-2003, 07:37 AM
s2n s2n is offline
Default Re: O.T. Glyph Firewire doesn\'t unmount
Initialize the disk using Mac OS disk utility.
Old 08-12-2003, 10:44 PM
It might be a solution, the other IBM I mentioned above was also formatted using Apple's, then what about the advantages of Glyph's own audio storage driver?
16 Gig RAM
Glyph Firewires
Motu MTP AV USB
Old 08-13-2003, 11:21 AM
dbullard1 dbullard1 is offline
This may well have something to do with the difference between the IBM & Western Dig mechanisms. Most likely, Glyph had tuned the Firmware in the bridgeboard to work with their drives only, and so swapping them out isn't as easy as it seems. Of course, this is only speculation.
I believe you've shattered and burned the waranty by doing this, but it is worth calling them and asking. They're usually helpfull in any situation. After all, that's why you spent the money in the first place...
Firewire drives unmount when I launch PT -- any ideas? andretti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-06-2011 02:23 PM
002 + glyph firewire: use 1 or firewire cards PDEES 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-08-2003 03:46 PM
firewire drive mount / unmount chucky b 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-05-2002 03:09 AM
For those with Glyph FIREWIRE drives Da Cryptic One 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-02-2001 12:25 AM
glyph firewire 5milefall 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-07-2000 02:22 PM
