Studio Wiring
Hey,
I just bought an ADC TT patchbay with the breakout punchdown panel. I am looking for some good wire to make cables and wire up the patchbay. I've heard really good things about the MOGAMI cable. Some people like the MOGAMI 2944 balanced console cable (26awg) and others like the MOGAMI 2534 balanced mic cable (22awg). Suggestions anyone? Any other brands that might be similar to MOGAMI? I am interested in any ideas that you might have. Thanks! CIGAM
Is This Cosmos or Chaos? |
Re: Studio Wiring
Go for the bigger (22)ga. wire.
Re: Studio Wiring
Where,
That's funny that you just replied because I was just reading one of your posts and I was thinking of emailing you. I have your email from a while ago when you helped me with a firewire issue. Hey, if you don't mind me asking, I want to balance all of my synth outputs-K2500s, JV1080 (Man, this thing is noisy), Proteus (Noisy too)- What do you think is the best way to do this. I want to run a balanced studio all the way around if I can. What do you think is the best most cost effective way to balance my synth outputs. I want quiet, hot signals. I know I got off my original post, but I figured I would ask anyway. Thanks! CIGAM
Re: Studio Wiring
If the outs are unbalanced, run them through DI's. However, if you keep yoru calbe runs short (under 15') you should not have any appreciable noise issues unless you live near a transmitter tower or power lines.
Re: Studio Wiring
What solutions have you found for synths like the JV1080 or the Proteus (original proteus)that are pretty "Hissy" units?
I'm trying to achieve a very quiet studio environment. Thanks! CIGAM
Re: Studio Wiring
hope that's of some help.. steve |
Re: Studio Wiring
Steve,
Yeah, that does help. Thanks for your reply. I have found that my JV1080 and Proteus are noisy just when they are on and idle. I have experimented with a direct box and it did help. I am rewiring my studio with Gepco cable and installing an ADC TT bay so do you think that I could get away with the direct boxes. Could I make something instead? Balanced power module to plug my Furmans into? Any ideas are appreciated, CIGAM
Re: Studio Wiring
so i'm still not sure what kind of noise you're talking about, though it sounds to me from your last post that you're not talking about electronic/ac "buzz/hum" but the "hiss" of the keyboard. the only success i've had with direct boxes is killing the buzz/hum. if it's solving your problem for you -- why make anything else (path of least resistance & all that....)
good luck! steve |
Re: Studio Wiring
Steve,
Yeah, the DI box does seems to reduce the output noise. Which is interesting b/c like you said, DI boxes usually elimnate ground loops and line noise. Now, I just read something on the Van Den Hul website: " removing residual ground currents flowing in your audio installation: Due to the fact that most audio equipment in your installation is powered by the mains voltage, an unavoidable hum voltage residual is induced on all cabinets and audio grounds. At all audio devices these residual voltages are of different magnitude (or phase) and will balance out by means of ground currents flowing through the shields of your interconnecting cables. Generally, these ground currents are in the same order of magnitude as the audio signal currents being transferred (microAmperes), and thus are likely to interfere, thereby reducing transparency and imaging. With the van den Hul POLARITY CHECKER, you can simply fine-tune your audio system to eliminate, or at least strongly reduce, these residual ground currents and thus improve your system’s performance." http://www.vandenhul.com/other/c-care.htm#polarity Could there be a polarity issue? I'm new to the whole "tech" side of this so I could be way off. I am really wanting to get my studio noise floor LOW. Thanks for your reply, CIGAM
Re: Studio Wiring
For punchblock, definitely 22 gauge. Make sure your rack stays put, punchblock likes to fall out if moved. Gepco is also a very good wire, made in Illinois and they sell direct.
Wiring up a studio, please help | rocksripley | ICON & C|24 | 1 | 11-21-2013 01:19 PM |
Studio Wiring | micline | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-13-2004 09:23 AM |
studio wiring | cigam | Pro Tools TDM Systems (Mac) | 31 | 07-12-2004 04:31 AM |
Studio Wiring | scuppari | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 06-03-2002 06:30 PM |
Studio Wiring ..... HELP!!! | activeman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-01-2002 12:52 AM |
