Digital routing help with effects
I currently have an AMIII but I am considering upgrading to the Digi001.
I have a Lexicon MPX1 which has S/PDIF I/Os. I also have a Alesis Q2 which has ADAT optical I/Os. Is it possible to send a digital signal to the Lexicon via S/PDIF and the Q2 via optical at the same time? Could I then return them to my mix digitally at the same time? The Digi001 Quick Start guide says you can only use one pair of S/PDIF at a time, but if I'm not using the Optical connector in S/PDIF mode and instead I'm using it in ADAT optical mode can I do this? Can I send out to an effects unit digitally but return it through the analog inputs? If not, then what are my other options? Thanks.
LANPARTY UT nF3 250GB RT Athlon 3400 DTR G.SKILL 1G(512X2) F1-3200DSU2-1GBLC ZALMAN CNPS7000B-CU RT EnerMax EG365P-VE FMA 1.3 RT GeForce2MX |
Re: Digital routing help with effects
One more thing...can I use the AMIII card AND the Digi001 together for more I/O possiblities?
You can use both the Spdif(coax) and optical as Adat Lightpipe at the same time. You can return them digitaly or via analog, your choice.
AMIII and 001 simultaneously. PTLE only lets you choose one playback engine. So unless there are some special drivers/extensions I don't think so. |
External Effects Routing PT10, Saffire Pro 40? | bigtime94z | Pro Tools 10 | 1 | 12-30-2013 12:38 PM |
External effects routing... | pguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-06-2008 06:11 PM |
Effects Routing | BobNunn | VENUE Live Sound Systems | 4 | 08-05-2007 12:31 PM |
Routing External Effects to Low Latency Monitor | joshbennett | Tips & Tricks | 2 | 06-03-2006 07:08 AM |
Routing MIDI from one soundbank to different effects pallettes | Joseph Anderson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-07-2002 08:25 AM |
