#341
Re: Enuff Q: How about some tips!!!!
Panorama 5, It's the mutts...
#342
Use Audio track as Notepad
Create a mono audio track. Make it small so it appears as a line between your other tracks. Create a region. Rename the region as a note to yourself. e.g. Guitar Rig 4 #32, Used SM57, Cmaj7 - or whatever. Now when you open a file you haven't seen for awhile you'll have floating notes reminding you of all the little things you did and the choices you made. Uses no CPU.
#343
Re: Use Audio track as Notepad
I also find it helpful to have such a track with regions that divide up songs into useful sections, labelled for instance V3.A2 for the second A-section of the third verse. Then if I want to select a section, or a number of contiguous sections to play or loop I just select those regions in the aux track and hit the space bar. This is substantially easier than using markers for certain kinds of work. You can also add notes to the regions on a section by section basis.
PT9.0.0, 3.0GHz Mac Pro, OS 10.6.3, 13GB RAM, HD6/Accel, Magma PE6R4, PRE |
#344
REAMPING GUITAR TRICK
Okay I first want to thank EVERYONE for making this thread. I've only been in PT for about a month so you can imagine what this resource is worth to me!!! Okay this isn't a protools specific trick and it's not technically the same as re-amping out of your DAW but it's a great trick for instant reamping. If you own a High Quality loop station such as the Boomerang or the Boss RC-50 you can come out of any A/B box and send your clean signal to the loop station and the other to whatever your recording through. Now create a loop of the part that your wanting to record. You can play this back while dialing in any EQ/Effects Combination with your analog gear. You can also now run the same take through any amp/cab/mic combination that you might have available. The only drawback to this is that it kind of has to be a same day re-amping but just to use it to dial in EQ an Effets is a big plus because obvioulsy it sounds better to capture what you want coming in that post editing. Also while it's looping you can audition many different Mics and Mic placements until you get exactly what you want. This can work for a vocal take as well although I would use this more for set up without killing up their voice. Hope this is helpful to some people. Thank You again to EVERYONE who has contributed to this post!!!
Joshua Hodge www.troytracks.com Pro Tools M-Powered 8.03 (2) Custom PCs w/Gigabyte Mother Board Windows XP Service Pack 3 & Windows 7 i5 Processor w/4GB DDR3 RAM Western Digital 150G HD 10K RPM Sea Gate 1.5TB HD 7200 RPM Sea Gate 1TB HD 7200.12 RPM Glyph 1TB External Drive 7200 RPM M-Audio ProFire 26/26 Focusrite Pro 40 (Linked via Dig I/O) Mackie Onyx 1640i M-Audio Oxygen 61 Roland V-Drums TD9 |
#345
greatest thread ever.
#346
I've been getting a lot of mileage out of the ordinary, grey, sitting-by-itself-in-the-corner Trim plugin. Some uses that may have not occurred to everyone are as follows:
[Most uses mentioned require instantiation of a Trim plug-in with Gain automation enabled.]
The one downside of using Trim gain automation rather than channel fader volume automation is that the channel fader volume automation can be modified with the yellow volume trim line. Unfortunately trim lines are not offered when modifying plug-in automation parameters.
#347
Ever find a spot where shoving your fader all the way to the ceiling still isn't giving you enough gain, but for other reasons you don't want to trim up the whole track? E.g. you want to pull up the tail of a long bass note for sustain. Put a send on your track that goes to the same bus or output as the track output and set it to pre-fader. Now you can add volume where needed by automating the send in the problem areas and muting or zeroing it away from those areas.
#348
#349
Here is a HUGE one ... get your speakers off the meter bridge, do not turn them on their sides either. And don't put a computer monitor between your speakers ... the monitor should be below the stereo field of the speakers. These are words of wisdom from a world-class studio and speaker designer.
Bad monitoring is such a huge issue ... mixes not translating out of a studio after spending so much time on a track is a big ol bummer! =) http://www.youtube.com/watch?v=-nOk7Relg0g
My Cool Company Info |
#350
The audio world is full of (mainly very expensive) placebos. Windows 10 Pro 64 Bit Pro Tools Ultimate (perpetual with active updates/support plan) RME Fireface 802, Focusrite Clarett+ Octopre, Eleven Rack (ERXP) Monitors: Yamaha MSP7 and Yamaha HS8S Asus RoG Maximus Hero Z790 (in a 4U slidable rack mount! ) Intel Core i9-13900k 5.4 Ghz (16 cores / 32 threads) 128 GB RAM G.Skill DDR5 6000 MHz (4 modules 32GB each) Boot disk: Samsung 980 Pro M.2 2TB Media disks: 2 x Samsung 980 Pro M.2 2TB in RAID 0 for current work, 2 x Seagate Exos X20 20TB mirrored for archive and backup Video: PNY/Nvidia RTX 3080 TI with a single 4K display Dell U3223QE 32'' |
enuff is enuff...I'm sick of the crashing! | hot lipps | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 08-04-2009 10:19 AM |
Enuff Problems, Let's Add Some Features!!!!!! | Kenny Gioia | Pro Tools TDM Systems (Mac) | 78 | 12-06-2007 01:17 PM |
Is my G4 400 Good enuff or dinosaur? | thumbolt68 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-15-2003 08:13 PM |
Is This good enuff for ProTools Digi001 | gruvnaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-03-2003 04:30 AM |
Enuff jibba jabba | ckerian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 03-18-2002 08:00 PM |
