Old 09-05-2009, 06:40 AM
starburst starburst is offline
Default mix 24 & mbox mini together?
Answer is probably no but can you run pro tools 8 (mbox mini) with pro tools 6.4 TDM mix at the same time?
I'm really happy with my TDM system but PT 8 is more geared for midi/composing with it's built in synth plugins etc. Don't really want another computer in the same room. Any work arounds?
Old 09-09-2009, 08:10 PM
zimmy2000 zimmy2000 is offline
Default Re: mix 24 & mbox mini together?
This is what I want too. But I'm using an old mac with panther, because for mix you can only use 6.4 with panther. If you want to use 8, you have to use Leopard. If your mac is fast enough you could use a dual boot OS. But my mac is ancient, and therefore won't handle leopard. So I want to use XP on a PC because both 6.4 and 8 work on xp. But I can't find a copy of 6.4 for windows. I'm assuming this would work under xp.
Old 09-09-2009, 08:26 PM
NickH NickH is offline
You can't have LE & HD installed together on the same OS...
You can however, have a duel boot machine with HD on one operating system & LE on the operating system on the other partition....
Cheers
N
“It’s because you touch yourself at night... ”
System Specs
Downgrading MBOX 2 to MBOX mini (Quick question) Mista808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-09-2011 08:29 PM
Am I Missing Something?! Mbox Mini, Mac Mini, Shockingly Bad gunark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-07-2010 12:58 PM
Mac Mini and Mbox 2 Mini Issues neilwilsonvoiceovers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-17-2010 09:34 AM
Please compare original mbox to mbox mini... mbart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-22-2009 12:04 PM
Quality Dropoff from Digi 003 to Mbox or Mbox 2 Mini? Steve7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-02-2008 02:10 PM
