Buffer errors in 'tools 8
I have a problem where, randomly, the buffer (a buffer) starts repeating audio, a bit like an out of sync delay, this carries on when I press stop, but stops when I press play again. it will also cause corruption to an audio file if I'm recording, in the form of little "blobs" of spurious audio every 2 seconds or so throughout the audio file.
I also have osx on the same machine and get the delay thing, but don't know about the other stuff. Also if I use plugins on aux returns, the PDC can't compensate. Gigabyte quad 6 motherboard, quad core cpu, 2 gig ram, win xp sp3. |
Re: Buffer errors in 'tools 8
I should also add that I'm using a single pci hd card, not accel.
Is it normal that the pci slot in the computer is a little shorter than that on the card? |
I also used to get the out of sync delay thing with it as well.. Cheers N |
digidesign is pretty good at blaming your computer and are your third party plugins ....they just can't get it right anymore... no matter what system you have they can find something that is your fault and say we're perfect your end has the problem . lame excuses update your video drivers uninstall your massey plugins .but at the end of the day we just want reliablity and a product that we can use day in and day out .. because this is our way of making a living................
6086, buffer underflow, hw buffer size and other errors on i7 | rhythmtechnologies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 05-30-2009 08:36 AM |
Buffer errors in Pro Tools LE; Solution to VIA OHCI issue | CJMD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 06-03-2008 08:29 AM |
Pro Tools 7.0 on XP (Boot Camp): Excessive Buffer Errors | Priory | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 05-09-2008 11:17 AM |
HW Buffer errors and Mass Confusion! 9093 Errors!! | guitarlancer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-08-2007 10:38 AM |
Buffer Errors / Buffer Problems? | freezegelman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-28-2006 11:50 AM |
