MIDI problem - can anyone replicate?
I'm on 2020.3, 10.14.6, HD Native.
Can anyone see if they can reproduce this on their system please? I'm currently in conversation with AVID Tech support who are being very evasive about whether they can reproduce this problem on their side. Their current suggestion is to "delete Pro Tools prefs" http://duc.avid.com/showpost.php?p=2562069&postcount=16 |
Re: MIDI problem - can anyone replicate?
no issue here unless i turn delay compensation off. sure you haven't turned it off by mistake? i'm on windows btw.
Yeah it's not delay compensation, you can see it's active from the mix window in the video I uploaded. Thanks for checking anyway.
Just replicated your test.
At buffer size of 32 I could record just fine. MIDI lined up as good as I would expect. Changing to a buffer size of 1024 made the instrument unplayable - the delay was too much for my ears. I found I had to anticipate the note hugely to make it sound even close to in time with the click. Once I muted the record track I continued hitting the keyboard note in time with the click, stopped recording and listened to the result, which was perfect.
He used to cut the grass...he was a very nice boy... |
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 Last edited by innesireinar; 04-23-2020 at 02:11 AM. |
So after a week of to'ing and fro'ing the "support" department have now decided this is a feature, not a bug.
"On a recording side, obviously, if you set your buffer size to 1024 you will experience a delay. The higher the amount of buffer size the higher chance of getting a delay during recording. You can just adjust your buffer size to a much higher amount if you are now on mastering the mix." No explanation as to why there's a delay, whether it happens on all systems or if it's just mine (hint: it almost certainly won't be), why they can't just build in some sort of correction so that MIDI can be played in on ANY buffer size. It's taken a week for them to admit that it just doesn't work as it should, after asking me to waste time doing things like changing the USB cable, deleting prefs, trying a different VI, etc etc. I'm so angry. |
I hate to say it again but Midi needs to be completely overhauled! Its a joke. AVID is the standard in post and film but yet when you try to "compose" or "create" it is bug ridden, cpu spiking and not efficient, sloppy, and just terrible. Embarrassing. And the reality is everyone knows and must use a competitors daw to do it...... How many years now?? Sad But hey! we have folder tracks now.....
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1 Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX. |
All DAWs will have throughput delay when you set the buffer high. Is that the question you're having? Or am I misunderstanding you? Standard practice is to set the buffer as low as possible when you're using VI's (like Battery.) |
Can Pro Tools and its plugins replicate the Avalon 737? | SteveGarman | Third Party Interfaces | 0 | 01-31-2016 01:30 PM |
Is there any way to replicate the swap feature in the MC Control? | KeyplayerG | Artist Series | 0 | 03-08-2014 03:46 PM |
MC Transport - Anyone replicate this crash? | whoever | Artist Series | 10 | 05-12-2011 02:42 PM |
Can anyone replicate this Transfuser error? | davegibbon | Virtual Instruments | 0 | 05-01-2011 05:45 PM |
Replicate A Track Including In/Out, Plugins Etc | beau johnson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-28-2005 01:47 PM |
