Old 12-21-2002, 10:42 AM
yobrooklyn yobrooklyn is offline
Default overlapping regions
whenever I drag a region over another and then move it away again, it appears to have deleted whatever was in the underlying region. How do I overlap without affecting the underlying region? For example if I try a cross fade, and decide I don't like it one day, it appears that if I remove the fade and move one of the regions, the underlying one is altered.
Old 12-22-2002, 06:59 PM
dummy20707 dummy20707 is offline
Default Re: overlapping regions
There may be an easier way around it, but you can for sure CLEAR the region that was altered (using edit>clear in the upper left) then go over to your regions list and drag the old unaltered region back to where you want it, or recreating it from your WHOLE FILE if you have to.
Overlapping Regions without.... Scorpio253 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 08-26-2007 05:36 PM
Overlapping Regions VWYF11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-13-2007 07:45 PM
Overlapping Regions Brad Newman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 01-27-2007 12:50 PM
Overlapping Regions G.I. Productz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-05-2004 09:45 AM
Overlapping Regions... SoftDesign 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-29-2004 12:59 AM
