ASIO Driver beta2 and instruments in Cubase SX
Come somebody help me with this?
I just installed the 2nd beta version of the ASIO driver provided by Digi. Beside ProTools i use Cubase SX. This works properly with the driver, but I have one problem. When I try to use an instrument in SX and link it on a midi track, there's no output. Is there someone who have experienced the same problems? Is this a known issue on the driver of are my setting not correct? I know the midi ports cannot be used when using the ASIO driver. But this is only the hardware midi port, isn't it ??? Would be great is someone could help me with this. |
Re: ASIO Driver beta2 and instruments in Cubase SX
Hi
I've had the same problem, I can't seem to record anything in cubase sx with the asio for digi002 driver...
.....S_L_I_C_E...... |
Question for you guys in this thread, sorry, I don't have an answer for your problem but I figure you may be able to help me [img]images/icons/smile.gif[/img]
It looks like you're running Pro Tools LE on Windows XP, using the latest ASIO drivers, correct? What do you do for real-time soft-synths? RTAS plug-in instruments or samplers in Pro Tools LE? Cubase SX VSTi? What about latency? The ASIO driver for Cubase SX had horrible latency with real-time soft-synths until I used the DirectX/DirectSound driver. I'm considering a DigiDesign/ProTools combination but I'm running Windows XP (P4 2.53Ghz machine) and have no intention right now to get a Mac G4, though this does seem the "right" way to go with DigiDesign stuff right now. |
Cubase SX3 +Mbox / ASIO Driver | skeeter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-07-2009 02:10 AM |
invalid asio driver on Cubase SX3. | ireah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-14-2009 05:13 AM |
Digi 001 Asio Driver w/ Cubase SL 2.0 | Illmatic | Tips & Tricks | 0 | 03-17-2004 04:54 PM |
Which ASIO driver w Cubase SX and Digi 001 | Jotown | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-20-2004 04:16 PM |
Cubase SX and Asio driver under PT 5.3.1 | mucky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-29-2003 08:24 AM |
