Old 03-29-2023, 12:24 AM
digidesign78 digidesign78 is offline
Default Re: PT 2023.3 keylayout problem (QWERTY-AZERTY)
Ok, the problem is : SHORTCUTS in the 2023 protools version are set with a QUERTY keyboard, you can change all you need (and save a user preset after) in the menu SETUP/KEYBOARD SHORTCUTS.
Let me know if it solved your problems
Old 04-04-2023, 03:22 AM
thmsrock thmsrock is offline
Hello,
so this is their final response :
I received an update from our team regarding the issue with the keyboard shortcuts.
Our team has confirmed that this is a bug and it has been logged on our end. Here's the bug number for reference: PT-299479. Feel free to subscribe to Pro Tools release updates on any of the two knowledgebase articles below:
Release Dates and Versions for Pro Tools (v9 and later, includes Pro Tools HD): https://avid.secure.force.com/pkb/articles/faq/en393795
Pro Tools Release Notes: https://avid.secure.force.com/pkb/ar...-Release-Notes
There is no further action at this time, and there is also no ETA on when it will be fixed. The standard procedure is to close the case, but reopen the case if you need an update.
Nice update guys
Old 04-04-2023, 10:31 AM
Diederikds Diederikds is offline
Thanks for sharing.
@avid, wow, just wow.
D
Old 04-05-2023, 04:48 AM
lagunarecords lagunarecords is offline
Same problem for me.
Pro Tools is always in QWERTY when I open it. He didn't save the AZERTY mode.
ProTools Ultimate 2023.3
macOS 11.7
Old 04-05-2023, 07:57 AM
outil outil is offline
Same here... and very annoying.
Lets see how important azerty users are to avid and how long the fix will take.
  #16
Old 04-05-2023, 08:01 AM
Originally Posted by Friedd View Post
I got it to work by unchecking the auto-switch preference then go to setup/keyboard shortcut, switch between "lock to US keyboard" and back to "follow keyboard" then it's ok.
but as soon as you quit PT you have to do it all again.
@Fredd, thank you for this!
  #17
Old 04-06-2023, 07:19 AM
Friedd Friedd is offline
Very welcome @outil
Just wondering,
do you , Azerty users, also have this problem with cmd+numeric shortcuts ?
Where for example, you can see cmd+1 triggering the request for transport palette, but it doesn't show up ?
just wondering if this is all related one another.
  #18
Old 04-07-2023, 01:33 AM
Very welcome @outil
Just wondering,
Yep, but I also had this problem with the last 2022 version, and the azerty issue wasn't there.
Also, when I bounce offline and import, the bounce goes to the start of the session, instead of aligning with the selection of the bounce. I guess I'll open another case for these malfunctions too
  #19
Old 04-07-2023, 01:37 AM
I did too have this cmd+num problem in 2022.
Hope next version won't brake the play/stop on the space bar ...
  #20
Old 04-09-2023, 08:38 PM
sifactory sifactory is offline
Phenomenon on "MacOS Ventura+PT2023.3
When I try to copy the title text in the session file save window, an alert sounds and I cannot copy the text, I can right click with the mouse and copy, but when I paste, 3 identical texts are pasted. Could this be a similar bug to the one described here?
AZERTY keyboard... Nese 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-19-2007 12:35 AM
Key commands azerty keyboard [solved] Eli V/d Vondel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-09-2006 10:48 AM
keyboard AZERTY QWERTY blashol Pro Tools TDM Systems (Mac) 1 06-11-2005 11:50 AM
ProTools 6.7 AZERTY Keyboard Shortcuts Big Problem George Dyson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-08-2004 04:12 AM
Shortcuts changes on AZERTY keyboard... igloo701 Pro Tools TDM Systems (Mac) 7 11-23-2004 01:58 AM
