ASIO driver vs DIGI 001
So, someone sent me the ASIO driver i needed to access Reason, but now REASON says that the soundcard is in use by another application.
How can this be? Nothing else is running. I tried both soundcard setups using the Sound manager in the control panel, and neither way worked. Whats up?? thanks. -kiley [email protected] |
Re: ASIO driver vs DIGI 001
I had the same problem at first. Try quitting out of every program, then restart. Just make sure you don't have any other audio programs running with Reason. (i.e. PT, iTunes, or whatever)
- Melow01 |
I tried that repeatedly and nothing works.
ANYONE????!?!?!?!?!?!?! |
what's the right URL to get the right digiASIO driver for Reason??
i think i downloaded the wrong one, as for everyone else it works great, but for me it's SHOCKING.... can someone post the link?? t. |
thank you so f***in' much. like an idiot i downloaded the wrong one.... no wonder it doesn't work.
later. uptown. |
DAE stays resident after quitting Pro Tools. Quit DAE as well. If that isn't the problem, try trashing your Reason Prefs, and replace the driver with a clean version (if you still have the original attachment). I had a similar problem because I had somehow corrupted the ASIO driver in the process of getting everything to work. I had to download a new file and do it again. Good luck.
Digi ASIO driver 64 bit | Greg M | Pro Tools HDX & HD Native Systems (Win) | 12 | 10-24-2011 07:53 PM |
DIGI ASIO Driver | GTBannah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-02-2010 02:36 PM |
DIGI ASIO Driver | GTBannah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-02-2010 01:30 PM |
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. | scottthafoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 04-19-2010 01:45 PM |
Digi 002 ASIO driver..? | FirstStep | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-26-2003 06:41 PM |
