Using Cubase 4.1 with Digi 001 midi&audio?
For some reason I cannot get midi and audio to work in Cubase. If you setup OMS to work with the 001 it will not initilize the audio.
Can anyone tell me what to do to fix this ------------------ |
Re: Using Cubase 4.1 with Digi 001 midi&audio?
leisure...
Did you enable the inputs? Panels -> VST Inputs. E. ------------------ Let he who is without rhythm cast the first stone...
Let he who is without rhythm cast the first stone... |
i too am having troubles with the 001 and cubase. i can play audio that already exists on my drive with no problem at all - all the outputs & buses are available and fully operational. I CANNOT, however, get cubase to allow recording. i suspect it may be my fault, but i feel like i have covered most all the possiblities. i am simply not getting a signal when a channel is record enabled and selected. what might i be overlooking?
Check Steinberg's latest revision (as of a few days ago) Cubase 4.1.1c or something!
"The original nipper" Throw me a bone (Telefunken DI is ok too) |
i did mak sure all the inputs were activated and an audio track was "record
enabled". still cannot get a signal into VST. Have no problem with playback of audio, including all the bus routings and plug-in routing as well..... |
Take everything out of your asio folder except direct i/o
RIO B. MABZ MUZIK(BMI) MAB PRODUCTIONz |
DIGI 002 rack & Cubase SX MIDI problem, please! | bstudiob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-01-2005 04:40 PM |
Core Audio for Digi 002 disconnect with Cubase | bricartiste | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-02-2005 01:52 PM |
Midi in Cubase-Audio in ProTools | stretto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-19-2002 12:52 AM |
PTF audio & Cubase MIDI? | edjog | Digidesign Hardware & Software | 0 | 06-04-2001 11:06 AM |
Cubase 4.1. Getting Midi and Audio to work? | lifeline | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-22-2000 08:45 AM |
