Overlapping Clips
I was wondering, if you insert an audio file into pro tools, say, a synth that has a lot of echo, and the clip lasts 10 seconds after the synths ended to make sure the echo isn't cut off, can you take that clip and put them back to back without the end of the first one being cut out by the second? Like have them overlap? Only asking because in Garage band you can't do it unless you make two separate tracks for each audio file.
Also, is there anywhere I can test out the software just to for simple things before I go out and buy it? |
Re: Overlapping Clips
No Pro Tools can only play one audio file at a time on a single track. So you could separate them onto two tracks like in Garage Band. Or you could create a cross-fade between the two regions (on the same track of course), which actually writes a new audio file with the two files combined.
Chris Neal :: South Plains College .: Program Coordinator & Asst. Professor in Sound Technology .: [email protected] .: Pro Tools Certified Instructor .: Pro Tools Expert Certified in Music |
no demo to download but a decent music store should have a demo station set up or maybe there is an introduction class available in your area
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Exporting Clips as WAVs, clips dont highlight in list | gigantorbuzz | Pro Tools 10 | 6 | 08-05-2013 01:07 PM |
Cross fades are not between clips but at the end or beginning of clips | phatbeatstudio | Pro Tools HDX & HD Native Systems (Mac) | 2 | 09-10-2012 02:08 AM |
Drag Clips = Delete Clips??? | Connor | macOS | 2 | 07-09-2012 07:50 PM |
Editing clips without creating new clips | dimebagslash | Pro Tools 10 | 2 | 07-04-2012 07:24 AM |
Overlapping Regions | VWYF11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-13-2007 07:45 PM |
