Old 10-19-2010, 10:38 AM
idris idris is offline
Default How to track down spinning ball
I've had a couple of spinning ball crashes recently. No error messages, the mac just hangs.
Any tips on finding out the cause?
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM
Over 30yrs experience in pro-audio - mostly for picture.
Old 10-19-2010, 11:11 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: How to track down spinning ball
Check system drive / users / your name / library / logs / crash reporter and see if there are crash logs for the time it crashed! it might indicate which thread in the crash log caused it and might mention the cause or plugin etc.
Can be many things from external drives to incompatible plugin in the folder. doesn't have to be in the session, just having an incompatible plug in the folder will cause such problems.
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-19-2010, 11:17 AM
Not trashed preferences yet as it's not too unstable (yet). Was hoping to head things off at the pass.
The Crash Reporter Log doesn't list anything for the last crash (ie nothing for today's date). How significant is that?
Old 10-19-2010, 08:12 PM
drBill drBill is offline
I'm not sure if I completely understand, but you're saying you HAVEN'T trashed pref's yet? That's the first thing to do, and some people do it regularly (once a week, or even more often). Look up at the top of this forum and get the PT pref and database trash tool. Worth it's weight in gold. Trash those pref's!
Old 10-19-2010, 10:36 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
I would also check the console messages for clues.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 10-20-2010, 06:50 AM
formfunction formfunction is offline
This is a cure sometimes... BUT if you use it regularly it is basic maintenance, and the "prevention" that makes a cure unnecessary.
Old 10-20-2010, 10:06 AM
Ok. Have trashed prefs. Time will tell wHether things have settled down.
But other than that, where do you find meaningful logs (other than the one mentioned above) and what do you look for in amongst the incomprehensible babble?
Spinning ball when I try to sync to Ext W/C SoundMoves macOS 11 06-24-2011 08:34 AM
Spinning ball when changing track size!!!! sound01 Pro Tools TDM Systems (Mac) 2 05-05-2007 05:08 AM
Spinning ball on save? Kelly M. Pieklo Pro Tools TDM Systems (Mac) 1 02-22-2007 12:53 PM
Spinning ball Mubeau Post - Surround - Video 5 08-15-2006 11:42 AM
Spinning ball at stop Faux Pas Pro Tools TDM Systems (Mac) 2 03-12-2004 04:38 AM
