#51
Re: Free Pro Tools Application - Delete Prefs/Database
Just installed this, many thanks for this great, time saving application....
Cheers! |
#52
forgive me for sounding dumb....but why would i need to be deleting Prefs/Databases????
www.christurbiville.com |
#54
Re: Free Pro Tools Application - Delete Prefs/Database now V2.0
Your utilities are extremly helpful. Thanks very much! I will be sure to push the PPD button soon.
I would love a util that was smart enough to copy a complete installed versions of ProTools to a holding place on the drive so I could have multiple versions and cs updates installed, and then copy the version I wish to work with back to the right place, all with a push of a button. That way users could still have their disk authorzations in place for Virtuatl instruments and go between versions when having problems, or needing to bring a fresh install back. . . Thoughts?
...for system configuration info see my profile (Click on member name) |
#55
Thanks alot JC,
This came in really handy last night... Ron
They're unlocking the picture on me again!!! |
#56
Thanks for waht appears to be a very useful app. i read it only works with 10.4... any Panther plans?
thanks, SB |
#57
I tried, but could not figure it out. I will try again soon. JC |
#58
To Howardk,
Pick up a copy of Stuffit Deluxe. There's a program for building pseudo-installers SEA Maker. You can copy directories of files into it then create a self extracting file that will put the folders back where they should be eg/ Library/Application Support/Digidesign &/Applications/Digidesign etc. Create a SEA file for each installation you want then just run it when you need a change. It may not be the most elegant solution but it would work. C |
#59
Re: Free Pro Tools Application-Delete Prefs/Database now V2.0
To Howardk,
#60
Re:Free Pro Tools Application-Delete Prefs/Database now V2.0
To Howardk,
Pick up a copy of Stuffit Deluxe. There's a program for building pseudo-installers SEA Maker. You can copy directories of files into it then create a self extracting file that will put the folders back where they should be eg/ Library/Application Support/Digidesign &/Applications/Digidesign etc. Create a SEA file for each installation you want then just run it when you need a change. It may not be the most elegant solution but it would work. C EDIT: Just tried this again with a v7 install and it doesn't seem to work. It did with v6 however. I'll report back |
Can't find Pro Tools 8 prefs to delete in Mountain Lion | Cartoonguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-18-2012 09:48 AM |
trash database and prefs in P T 8 ??? | not2tech | Pro Tools TDM Systems (Mac) | 1 | 10-06-2009 12:32 PM |
I delete prefs and the Database open session then system crashes 8.0.1 | philip888 | Pro Tools M-Powered (Win) | 8 | 09-10-2009 06:42 AM |
Free Pro Tools Application - Delete Prefs/Database | JC925602 | Pro Tools M-Powered (Mac) | 1 | 03-21-2007 03:04 AM |
Free Pro Tools Application - Delete Prefs/Database | JC925602 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-18-2007 11:20 AM |
