#141
Re: Free Pro Tools Application - Delete Prefs/Database now V2.1
PT HD 8.0.3 now saves PT prefs with the filename "Pro Tools HD Prefs", whereas the helper aspplication restores the prefs with the name "Pro Tools v8.0 Preferences" so the restored file is no longer referenced by Pro Tools.
Any chance of an update to fix this please? |
#142
Thank you very much. A very usefull tool. I will donate!
Mac OS X 10.5.8, iMac 2.66 GHz Intel Core 2 Duo, 2 GB 800 MHz DDR2 SDRAM, Pro Tools LE 8.0.1, Digi Rack 003 |
#143
Does this still work / needed with 8.0.3 ?
Richard Spooner Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM. www.spoonsound.com |
#144
No the App needs to be updated, as the way PT stores it's Database files has changed... you now need to MANUALLY go to
Macintosh HD/Library/Application Support/Digidesign/Databases/Unicode/Volumes Make sure Pro-Tools is NOT launched, and trash everything in that folder. IF you've still got "Digidesign Database" folders, on the root of ANY of your Hard Drives, they can be trashed too, PT doesn't use them anymore... the App WILL get "Those" but not the ones proTools 8.0.3 is currently using.
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
#145
Thanks Kingfish ...
#146
JC |
#147
JC,
the app does not seem to be working in 8.0.3 anymore. when i try to restore from a backup, my prefs do not come back. they default back to digi's setup. i have tried this several times with no luck. anyone else seeing this. thanks in advance and thanks for this great app. zeeman |
#148
JC |
#149
Thanks JC,
I'll check it out. zeeman |
#150
Hi JC, Great little app - Thanks!
I'm using PT 6.4.1 on OS 10.3 and i keep getting an error when i use the app. I did all the files individually to find the culprit and it's the com.digidesign.protools.plist file. This is a normal one to get corrupted to, so i'm curious what the issue it. This is what i get: AppleScript Error Can't get text 33 thru 0 of "". (-1728) any help? Thanks. Jive |
Can't find Pro Tools 8 prefs to delete in Mountain Lion | Cartoonguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-18-2012 09:48 AM |
trash database and prefs in P T 8 ??? | not2tech | Pro Tools TDM Systems (Mac) | 1 | 10-06-2009 12:32 PM |
I delete prefs and the Database open session then system crashes 8.0.1 | philip888 | Pro Tools M-Powered (Win) | 8 | 09-10-2009 06:42 AM |
Free Pro Tools Application - Delete Prefs/Database | JC925602 | Pro Tools M-Powered (Mac) | 1 | 03-21-2007 03:04 AM |
Free Pro Tools Application - Delete Prefs/Database | JC925602 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-18-2007 11:20 AM |
