Old 10-26-2006, 03:30 PM
Royalston Royalston is offline
Default Pt on new user account -how can I share my files?
Hi
The only way Ive managed to Launch PT is on a second user account. Unfortunately this account doesnt have access to my documents folder where I keep all my samples.
How can I make folders 'common' to both users? Switching the ownership to the second user isnt an effective solution because I now use both users....
Im sure this aint hard
R.
Old 10-26-2006, 04:17 PM
Starcrash Starcrash is offline
Default Re: Pt on new user account -how can I share my files?
Most folks store their samples or sound effects libraries on either a second internal drive or an external drive. I assume you are already using a second drive as a record/ playback volume. If there is sufficient space, then transfer your library there. If not, drives are dirt cheap these days (especially if you just need one for storing samples and not for recording audio). I'm also assuming that you have your sample library backed up for that day when the drive fails (and it will happen eventually).
p.s. If you really, really want to keep your samples on your system drive, you can use the "shared" folder under System>Users>Shared.
Good luck.
Pascal Garneau | IMDb
Old 10-26-2006, 08:19 PM
Craig F Craig F is offline
you could move them to your Public folder
Thank you,
Craig
Wrong Files listed in My AVID User Account RokVox macOS 1 09-15-2012 03:18 PM
Wrong Files listed in My AVID User Account RokVox macOS 0 09-14-2012 01:02 PM
PT set up new apple user account epiphone macOS 2 03-01-2012 03:31 PM
Problems downloading files User account CLASS-A-DUDI TAMIR macOS 1 04-10-2011 12:47 AM
Share smart User settings... GW Artist Series 4 01-05-2011 01:36 PM
