Old 06-21-2010, 03:53 AM
anti_75 anti_75 is offline
Default Mbox 2 mini Snow Leopard(10.6.3) problem
I have a problem with a Mbox2 mini device under Snow Leopard 10.6.3.
After I try to run ProTools LE, I got the following error message: "Unable to locate Digidesign hardware"
I used the installer I found in the hardware box (LE 8), then I updated it to 8.03 and installes CS2 too.
Everything looks okay, install went fine, I can hear system sounds through Mbox2 mini.
Status is "Connected" in System Preferences but if I try to run ProTools, I got the error message above.
The device works fine under Leopard 10.5.
Did I something wrong, can you tell me what could be the problem with Snow Leo?
Thank you for your help!
Old 06-21-2010, 10:00 AM
DigiTechSupt's Avatar
Default Re: Mbox 2 mini Snow Leopard(10.6.3) problem
Which computer model is this? Have you tried a different USB port?
Avid Audio Tech Support
Support FAQ
Old 06-21-2010, 10:26 PM
it seems like the problem is solved: i re-installed (clean) Snow leopard and the problem is missing.
Snow Leopard and mbox 2 mini stebit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-16-2012 01:55 AM
mbox mini (snow leopard, pro tools 8) gloommerchant 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-27-2011 11:27 AM
Is anyone running bootcamp with snow leopard and xp wit a mac mini sbag 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-07-2010 07:33 PM
MBox2 Mini Problem on Snow Leopard OSX 10.6.3 elcw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-31-2010 11:02 AM
MBox 2 Mini w/ Garageband w/ Snow Leopard? CalebB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-01-2009 11:39 AM
