Hi, Im new to Pro Tools, just switched over from Logic and I'm having big problems keeping my tracks under 0.0. In Logic the stock limter I used actually kept the signal from going over 0.0db, and I could adjust all the setting and the signal would stay under 0.0. I've tried everything within the Maxim limter and can't seem to keep the signal from peaking. Maybe its my inexperience with protools but I dont understand why this is so complicated, when it was so simple in Logic. Somone please help, this is really messing with my workflow and MY SOUND.
Thanks much. holla! |
I had the same thing happen with Maxim..one thing that worked okay was to put TWO of them on the Master Fader. Then each one doesn't have to work as hard and it's better at stopping peaks. But, the best thing I ever did was to get the Final Plug from Wave Arts (www.wavearts.com).(Haven't used Maxim since.) This will NOT let anything go past -0- and it's very transparent. In most cases, the "CD Mastering" preset works just fine, but everything can be tweaked. I think it's $149 by itself, or you can get the whole Powersuite 5 and get a real killer reverb, eq, etc. Also, you can demo it for free for 30 days, but if you try it, be prepared to buy it. You'll like it that much.
Maxim:
Set the Ceiling to -0.1 dB. Leave Mix at 100 % and the link button on. Now adjust the level using the Threshold fader. The output will not clip, but the sound degrades quickly when the "Atten" bar starts to work. A much better mastering limiter is the Massey L2007. I use it everytime. 89 USD to buy it, and there's a free version too if you want to try it first. http://www.masseyplugins.com/index_v2.html?page=l2007 |
Hey thanks alot for the responses. I'm going to check out both demos for the 2 mastering plugins. Much appreciated. I wish Pro Tools came with a nice set of plugins like LOGIC. Its pain but I guess thats the reality of Pro Tools
Thanks again. -knetic |
Keep this in mind-most mastering limiters will have lots of latency(because they "look ahead" and grab transients before they clip). Some other compressors have little or no latency(BF76 is one of my favs). As long as you record at 24 bits(highly recommended), you do not need to hit the input meters much more than halfway to still have good signal to noise ratio AND good headroom. Also, remember that a plugin limiter on a track that is being recorded, is NOT stopping clipped recordings as plugins act on the audio streaming off the hard drive and not the incoming audio.
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C https://www.facebook.com/search/top/...0sound%20works I started in this business with nothing..........and I have most of it left ![]() BTW, my name is Dave, but most people call me.........................Dave |
The other thing to consider is that your overall mix is way too high. Maybe you need a bit more headroom in your mix, and then you can use the Limiter to bring the mix up to CD level. Just a thought.
I have the same problem and usually get around it by inserting a 15:1 compressor before the limiter and having it grab all of the quick transients before it has the chance to break through Maxim.
Why is Maxim so bad? According to the manual it "looks ahead" and "you can set it, leave the room, and come back knowing what your db ceiling is..." riiight. |
[QUOTE]
Why is Maxim so bad? According to the manual it "looks ahead" and "you can set it, leave the room, and come back knowing what your db ceiling is..." I won't say it's "BAD" but it sure doesn't stop thoe peaks as well as the Wavearts Finalplug. When set to do so you really hear it working on the signal. Again, FinalPlug is MUCH more transparent. Just my own humble opinion, having tried both and settled on the one that does the best job for me... |
Midi Studio Setup problems & Plugin problems | J Nauti | MIDI | 0 | 03-02-2010 12:04 PM |
Computer Problems vs Pro Tools Problems | mudlake slim | Pro Tools M-Powered (Win) | 1 | 07-14-2006 09:09 PM |
Rewinding Problems, Cutting & Pasting Problems | Nikki | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-22-2005 02:19 PM |
Limting on Recording using 002 | h'biki | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 19 | 07-18-2003 02:17 PM |
PC Probe problems. Any overheatingg problems with Digi 001 | Ajay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-03-2002 06:30 PM |
