Display stuff
This is a relatively small thing, but is anyone else getting what you might term "sticky graphics" with version 2018.12? E.g. sometimes a small portion of the mix window doesn't "clear" when you switch to, say, the edit window, and you're left with a bit of "graphic debris". Or sometimes when you're working fast and applying a fade the play bar leaves behind a bit of a "graphic" mess. None of this is affecting my workflow particularly, it just seems to have got a little bit worse with each new release.
Re: Display stuff
Yeah I get that a little bit. Also a lot of -9173 when scrolling vertically in the edit window, which seems to be graphics related.
Re: Display stuff
E.g.
http://duc.avid.com/attachment.php?a...1&d=1548428831 http://duc.avid.com/attachment.php?a...1&d=1548428831 |
Re: Display stuff
Rob MBP 15 2018 macOS Big Sur 11.6.8 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II ........and a bowl of M&M's |
Re: Display stuff
Understood it's not the same issue exactly. Still...
Bob Without a song The day would never end |
Re: Display stuff
Worth a try. Thanks!
Re: Display stuff
Following happens to me from time to time
When you accidentally press alt cmd = the edit or mixer windows opens in a new tab in the edit or mixer tab. First i was unaware of this Feature but when you have activated two tabs you get all kind of Display errors including that the mouse does click a few mm besides. Ther could be also crashes. Maybe you are working accidentally in a second tab Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+ |
Digi Tech Sup: Color Display & Aux Send Display bugs | nob turner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-07-2010 02:43 PM |
Display name in channel strip Display | Roll | ICON & C|24 | 1 | 08-08-2010 08:24 AM |
Sesssion from dual display studio to single display studio | rafukyo | Pro Tools TDM Systems (Mac) | 2 | 02-09-2009 06:32 AM |
Plug-ins List display, view of the screen display | andre67 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-23-2007 03:24 AM |
Cinema display and studio display | Nick Le Mon | Pro Tools TDM Systems (Mac) | 0 | 07-27-2002 08:41 AM |
