Window Manager of Pro Tools 12 - MS Windows vs Apple OS X
I recently installed PT12 on a windows desktop too, because in large projects the processing power of my MacBook isn't sufficient.
Comparing PT 12 on Windows and an OS X it stands that in the Windows version all windows are embedded into one major window. Contrary to the OS X version, where all windows are "free" and not embedded into one major window. Why is this the case? Are there any plans to change this in the windows version? Especially If you are working with multiple monitors, these approach (all windows embedded into one major window) isn't very userfriendly. |
Re: Window Manager of Pro Tools 12 - MS Windows vs Apple OS X
Feel free to vote : http://protools.ideascale.com/a/dtd/...a-tab-comments
My workaround is a template with window configs, where the main window is stretched to the best regarding the different monitor resolutions.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
So sad that an industry standard software doesn't delivers the same user experience in its different OS versions. |
Maybe. May need 1286 positives votes, maybe 30 negative votes : http://protools.ideascale.com/a/idea...e?pageOffset=0
Do a search, there are ways to do this.
That said, it hasn't been an issue to me, maybe because I'm use to how so many Windows programs work. For Pro Tools, just stretch the background window across your monitors, and arrange the Mix and Edit window how you want.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
After you do what Benoni said and have the arrangement you want, exit ProTools by pressing ALT and F4 (at the same time). The next time you open ProTools, your configuration should be there.
The only thing that will mess it up is if you change monitors (or resolution). I swapped out one of my monitors and if I open up an old session, I have to resize the mix and edit windows.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
Every other DAW i've worked on(studio One, FL studio, Sonar) have their own window design with natural support for multiple monitors. |
I have had no issues running multiple screens on Windows. Its simply a matter of stretching the parent window to fill the screens where you want to place MIX and EDIT windows. I currently run 3 screens here. MIX and EDIT are on 2 screens and the third is home to any floating windows I wish(usually has the system resource meter, memory locations and FabFilter Pro EQ that sits on my Master track for the handy spectrum graph).
MIDI Editor window won't close straight away with apple-w | midnightrambler | Pro Tools 12 | 11 | 09-29-2015 03:17 PM |
Suppress Task Manager window? | reichman | Post - Surround - Video | 8 | 02-03-2012 12:35 AM |
How about an Apple Sound Manager RTAS plug-in? | Steve MacMillan | Pro Tools TDM Systems (Mac) | 2 | 11-04-2005 12:07 PM |
Apple 20" Cinema for both Edit and Mix window | Imagine | Pro Tools TDM Systems (Mac) | 3 | 07-31-2005 10:01 PM |
Windows server 2003+windows resource manager. | odysseys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-20-2003 10:02 AM |
