Old 11-07-2012, 11:20 PM
Alex Casey Alex Casey is offline
Default How to set Toontrack SD 2.0 plugin in PT 10 HD
Hi!
I'm new in PT and have just begun using PT 10HD with HD Native card. I've got Toontrack SD 2.0 plugin installed in my Mac Pro (2008). I checked that it is supported by PT. How can I add it in the list of Plugins or Instruments?
Old 11-08-2012, 12:07 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: How to set Toontrack SD 2.0 plugin in PT 10 HD
Originally Posted by Alex Casey View Post
Hi!
When you installed SD2 did you install the RTAS (or AAX native if available) version?
If its installed ok it should be in the native plugins list under instruments.
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-08-2012, 01:05 AM
bradch00 bradch00 is offline
SD2 should be available in the list of instruments when you create a stereo (not mono) instrument track. Also insure you have updated to SD 2.3.0.
Pro Tools 12, Studio One V3.x
iMac 27" 5k i7 4Ghz, 32GB RAM 1TB Flash (OS X 10.10.x)
OWC Thunderbay Mini (4TB SSD)
Interface: Antelope Audio Zen-Studio
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
Macbook Pro 8GB RAM, 512GB SSD Audio(mobile rig)
Old 11-08-2012, 01:24 AM
I don't remember. I use it with Logic as AU plugin. How I can check if I got SD RTAS installed?
Old 11-08-2012, 01:33 AM
Stig Eliassen's Avatar
Mac HD > Library > Application support > Digidesign > Plug-ins
Old 11-08-2012, 10:04 AM
Thanks a lot! I see all plugins with dpm extention in the folder but I can't choose any instrument. I make empty instrument track and don't see plugins. when i'm trying to select input the plugin button is grey and inactive
Old 11-08-2012, 10:46 AM
There are too many plugins but i don't know how to activate it
Old 11-08-2012, 11:55 AM
EDIT:
In the Mix window... are Instruments viewable?
View (menu) > Mix window views > make sure Instruments is checked.
Old 11-08-2012, 12:23 PM
Originally Posted by PT Lover View Post
EDIT:
i did as you recommended. I see only midi ports And no any virtual instruments.
Old 11-08-2012, 12:30 PM
But I see how plugins are loaded while launching PT It makes me crazy.
Toontrack AAX 2 DRC Music Pro Tools 11 0 06-28-2013 08:32 AM
Toontrack AAX lennieh Pro Tools 10 10 01-13-2012 10:51 AM
Strike vs Toontrack ThunderHorse Virtual Instruments 14 08-16-2010 07:22 AM
Another toontrack question frankielouis Pro Tools M-Powered (Win) 3 05-01-2009 02:11 PM
Anybody using Toontrack EZ Drummer The Dougfather 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-21-2006 12:53 PM
