Hotkey /shortcut to toggle pre/post fader?
Guys/Gals,
Is there a shortcut on the keyboard or 003Factory that toggles mix window between pre and post fader? If so why the hell not! Thanks' JG
2.66GHZ Imac - OSX10.5.6 Intel Core 2 Duo 3GB Ram 320GB Internal HD 70GB-OWC Firewire Audio Drive Digidesign 003Factory, MPT2, Protools 8.0.3 |
Re: Hotkey /shortcut to toggle pre/post fader?
Sorry, but I'm not really exactly understand what you try to achieve here.
Toggle the mix window??? Do you want to change the sends or what? Please explain it a littlebit.
my blog:Tamas Dragon |
Thanks for the reply,
Is there a shortcut keyboard move or a button on the 003 that changes the meters in the mix window from pre fader levels to post fader levels for all tracks and visa versa. You use pre fader levels to set recording levels, trims etc. I can access this setting via the options at the top of the page but surely there must be away to do this on the fly without having to use the mouse? Thanks JohnG
Use the Apple, System Preferences, Keyboard settings to create a short cut key of your choosing. Anything in a menu option can have a shortcut key created there (I do it for show/hide region names.)
Yep this is how you do it.
Hotkey to toggle conductor? | jschmidtiii | macOS | 4 | 12-17-2013 08:10 AM |
Toggle automation shortcut | henrikas | Pro Tools 10 | 3 | 02-28-2013 02:24 AM |
shortcut for pre/post-fader METERING switch. | Stefan Luan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-04-2006 04:17 AM |
Help me toggle the view with a shortcut | Saar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-09-2003 06:47 AM |
keyboard shortcut to toggle pre/post roll | rlcowa@work2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-13-2001 02:53 PM |
