Avid Omni Digital Out Problem
I'm having an issue with the Omni digital output connected to my MacPro 2012 digital in and would appreciate some help. I'm trying to use output 7-8 to the digital in on my mac. I've got it working fine in the opposite direction with digital in on the Omni from the mac digital out but I'm stumped with getting it going the way I need it to.
When optical S/PDIF is selected in Optical Output Format the Optical S/PDIF option for the output is greyed out. When ADAT optical output format is selected the ADAT outs show but the S/PDIF is greyed out. Not sure if this is the problem? I've tried all the ADAT outputs but nothing happening. Maybe I've missed something simple? Screengrabs attached... Thanks. |
Re: Avid Omni Digital Out Problem
I've solved the problem in case anyone comes across the same issue.
In Monitor tab of Hardware Setup I had my ALT 1-2 set to Digital which was causing the Optical S/PDIF option to be greyed out. Switched them to a different output and solved :) |
Avid HDX + Avid HD Omni + Magma Expressbolt 3T | _Khonnor_ | Buy & Sell | 0 | 06-18-2018 12:25 AM |
Avid Omni - Digital I/O does not engage after changing in Hardware Setup | anotherfilip | Pro Tools HDX & HD Native Systems (Mac) | 2 | 12-11-2017 04:26 AM |
Avid Pro Tools HD Native Card w/Avid HD Omni I/O | Digitaliz | Buy & Sell | 0 | 02-19-2017 04:32 PM |
HD Omni digital IO question | Verve111 | Pro Tools HDX & HD Native Systems (Mac) | 3 | 09-14-2012 11:48 PM |
Omni Digital 1-2? | Cliffy_Boy | Pro Tools TDM Systems (Mac) | 3 | 12-22-2011 02:45 PM |
