Hardware Problem..
Hello,
I'm a new user of Protools 9, and have purchassed a ULN 8 to work with it. But I'm having problems assigning the ULN8 as the Hardware interface. I was connected FW800 to a G-RAID Mini and then FW800-400 into the ULN8. When I went to select hardware I was only given the option to select an "Aggregate device". If I tried to setup this device the the ULN8 would show in the list but was not selectable as a standalone device. If I tried to slecet the ULN8 as the current playback engine, ProTools would try to relaod the session but "Quit unexpectedly" (when is a crash not a crash?). I've just tried connecting straight into the back of the ULN8, and it showed up, but I can't select any other Interfaces with it (I also have an Apogee 1). Thinking I was getting somewhere, I tried restarting, but the session won't reload. ProTools just cras... sorry quit unexpectedly again. No-one else I can find on the internet has troubles with ProTools and Metric Halo boxes. I'm feeling all alone!! If anyone has anything they can suggest I'd be grateful! Many thanks |
Re: Hardware Problem..
Hi Jack, maybe this should help.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Re: Hardware Problem.. PLEASE HELP!!
Hello,
Thanks for the videos. Nothing seems to deal with setting the hardware up in the first place. It's just assumed that it will work. And indeed it seems to for everyone else with a MH box. I've just reverted to 10.6.6 and the problem hasn't gone away. Tried holding down 'N' on bootup. Protools gets as far as "Loading Transport Controls" and then gives up. Very frustrated!! Grrrrr |
did you install the hd drivers after you installed or updated pro tools because it's not installed with pro tools
it's a secondary install not included on the disk, it is on the options install disk or as a separate download IMPORTANT: Driver Updates REQUIRED for Pro Tools 9 Installation (PDF) However, if you are updating to Pro Tools 9.0.1 or 9.0.2, Avid recommends installing the latest device drivers afterinstalling Pro Tools 9.0.1 or 9.0.2.
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Can't Find Hardware Problem - I don't use hardware! | sevenk | Pro Tools 10 | 3 | 10-29-2012 09:55 AM |
pt 9 hardware problem | scopelinio | macOS | 2 | 02-06-2011 03:16 AM |
Unable to locate hardware - OS problem or hardware problem? | Petie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-16-2007 05:07 PM |
DIGI 002, Problem installing hardware driver "cannot find hardware" on install | inevitable realisation | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 26 | 08-21-2003 02:03 AM |
MAC Hardware Problem | jasona | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-08-2003 12:49 AM |
