Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 05-01-2020, 07:00 PM
studiojb studiojb is offline
Default Should I deactivate plugs while over dubbing?
With delay compensation active, If I'm overdubbing, do I need to deactivate any latency causing plugins on the the other tracks I'm playing along to?
I already do this to anything on the master buss. I just don't know about the other tracks I'm playing along to.
I don't track with any plugs on the recording track.
Old 05-04-2020, 10:52 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default Re: Should I deactivate plugs while over dubbing?
I usually freeze everything before overdubbing if the session is big, so I can use a smaller buffer size and prevent delays.
X99 | i7 5960x @4.6GHz | 64GB GSkill DDR4 | Nvidia GTX 950 | Samsung 950 Pro NVMe 256GB | Samsung SM961 NVMe 1TB | Samsung 850 EVO 1TB | Samsung MZ7PD256 SSD 256GB | Kingston 120GB SSD | WD Black 1TB x2 | G-Drive 4TB x2 | WD Elements 4TB | Audient ID14 | PT2020.5 | Windows 10 Pro
Old 05-05-2020, 09:18 PM
I have done this, as well as disabled any plugs with latency. I just didn't know if I had to? Also, does buffer setting come into play if I'm not using a VI or any effects, and monitoring through an Apollo? I didn't think so but now I'm not sure.
Deactivate Plugins when Scrubbing spock999 Pro Tools 2018 2 09-10-2018 12:21 PM
Need to deactivate surround I/O in PT9// onepercentfree Pro Tools TDM Systems (Mac) 0 11-23-2010 10:37 AM
Need to deactivate surround I/O in PT9// onepercentfree Post - Surround - Video 0 11-22-2010 11:21 AM
Deactivate all plugins? Beauchampy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-22-2006 11:19 AM
Deactivate TDM plugins eurosurfer Pro Tools TDM Systems (Mac) 2 09-03-2001 08:01 AM
