Old 02-18-2015, 01:38 AM
studiojb studiojb is offline
Default PT11 Crackling Entire Time
Constant crackle the whole time I'm trying to mix. Played around in Playback engine and gets a little better or worse.
Headphones straight in. Only hardware is Ilok.
Any help would be much appreciated.
PT11.3.1
MacBook Pro (Retina, 15-inch, Late 2013)
Yosemite 10.10.2
Quad core 2 GHz Intel Core i7
8 GB 1600 MHz DDR3
Intel Iris Pro 1536 MB
Old 02-18-2015, 02:06 AM
Nearlymen Nearlymen is offline
Default Re: PT11 Crackling Entire Time
Had a similar problem that drove me nuts recently. Had a low level crackle that came out of no where. Eventually though sorted it. I had fiddled about with some USB leads and inadvertently re plugged my m-box into a USB 3 port instead of a USB 2 it had previously been connected to. after a lot of messing about I went to reinstall the drivers and saw the note on the download page saying USB 3 ports caused a problem, swopped the lead to USB 2 and all was fine !
May not be your problem, but worth noting !
Cheers
Clive
Old 02-18-2015, 07:40 AM
sw rec sw rec is offline
(A) What interface, and (B) is your sync source set to "internal?"
Old 02-18-2015, 08:52 AM
"(A) What interface"
No interface. Just plugged headphones in to laptop next to Ilok dongle.
"(B) is your sync source set to "internal?"
I can not find this setting anywhere. Keep in mind we're talking PT11. Closest I can find is in hardware setup - Pro Tools aggregate i/o and says "built - in microphone" and is at 48/24 the same as the session.
Old 02-20-2015, 09:06 AM
So, to answer my own question, and possibly help others, the solution has to do with adjusting my mac preferences settings. Once I made sure it was on the output of "headphones port" the problem seemed to disappear. Although it may be a combo of adjusting things. My current settings are:
Mac prefs for audio - input - protools aggregate device
- output - headphones port.
Protools settings under hardware:under protools aggregate - input mic is clocked.
Old 02-20-2015, 09:29 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Cheers
Clive
Sometimes re-seating a connector solves the problem. Or trying a new cable may help too.
The Ignore Errors During Playback/Record option determines how Pro Tools responds to error re- porting from the Avid Audio Engine (AAE) during playback and recording. This can be useful when working with instrument plug-ins where you care less about clicks and pops in the audio signal while you work on composing and arranging. Once you are ready to work on the final mix you should dis- able this option.
How is that option set?
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
PT11 launch time mesaone Pro Tools 11 23 04-28-2015 10:09 PM
Long time since last PT11 update Sam C Pro Tools 11 3 04-29-2014 11:39 AM
Shifting an entire session in time FretlessBassman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 10-02-2009 04:08 PM
Pushing back the entire songs start time. d00m1001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-23-2009 06:30 AM
PT 8 will not play entire Quick Time file... matthewacacia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-17-2009 09:16 PM
