Old 04-24-2020, 08:05 AM
studiojb studiojb is offline
Default Does H.E.A.T. only work at 192Khz
Does H.E.A.T. only work in 192Khz? Thinking about buying, but I mostly work at 48Khz.
Regular ProTools 2020.
Apollo Twin
Macbook Pro
Old 04-24-2020, 08:16 AM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Does H.E.A.T. only work at 192Khz
Hi Heat works at whatever sample rate PT supports. So your good and Heat is good indeed !
- Jesus Alvarado -
Keep the volume UP !
Old 04-24-2020, 08:26 AM
Thanks for the reply. I'm still confused and I suspect I'm misunderstanding you about the phrase "whatever sample rate PT supports".
On the Heat product page it says "Sample Rate Support" and then only lists 192 kHz.
Old 04-24-2020, 08:27 AM
JFreak JFreak is online now
up to
Old 04-24-2020, 08:37 AM
Fantastic, Thats what I was hoping! Thanks so much.
Old 04-24-2020, 09:19 AM
Quick note: H.E.A.T. seems to be the only on that says "Sample Rate Support" and then only lists 192 kHz.
Other plugins say "Max Sample Rate: 192Khz".
I'm hoping it's just different verbiage.
Old 04-24-2020, 09:22 AM
Rest assured HEAT works on all sample rates up to 192 kHz
Old 04-24-2020, 10:02 AM
Thanks again!
Old 04-24-2020, 06:54 PM
JoelG's Avatar
JoelG JoelG is offline
Using HEAT right now on 48Khz projects - works :)
Joel
Jam Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 2020 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 10 Pro
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
Old 04-24-2020, 08:18 PM
Yea, it just works.
Just took a minut to think about HEAT and the first it was introduced was PT 8.1.1 HD. Been using it ever since and almost always with 10 o'clock 2 o'clock settings. Hard to think about mixing without HEAT any longer.
192khz recording capt kirk Pro Tools 9 1 02-12-2012 09:16 AM
I cant go to 192KHZ KINGDRAGON Tips & Tricks 2 01-29-2010 11:57 PM
Anyone recording at 192kHz? Rupert Limehouse Pro Tools TDM Systems (Mac) 17 10-07-2009 11:36 AM
How many of you record on 192kHz? mantaray Pro Tools TDM Systems (Mac) 3 07-02-2005 09:18 AM
Possible configurations to *get* to 192khz Stephen J Pro Tools TDM Systems (Mac) 2 02-13-2004 10:25 AM
