Old 02-19-2003, 07:46 AM
Dweizmann Dweizmann is offline
Default Launching PT Free: Stuck on "Creating Plug In Array"
My PT FREE freezes while launching. [img]images/icons/frown.gif[/img]
At the bottom of the box it says "Creating Plug In Array: Long Delay" or something close to that...
Is there anything I can do to get it past this point?
Thanks!
Old 02-19-2003, 06:32 PM
M.Brane M.Brane is offline
Default Re: Launching PT Free: Stuck on "Creating Plug In Array"
Looks like an extension conflict or a corrupt file to me.
Did you make a stripped-down ext. set for PTF?
Have you checked your system with a utility like TechTool?
Old 02-21-2003, 05:07 PM
planet X planet X is offline
Or you could try trashing the PT's preferences before launching.
also try removing the plugin that seems to be causing the freeze (that is if it is in fact a plugin thats causing the freeze)
Failing that simply tr a re-install.
Still not working? Then could very well be a hardware conflict somewhere.
HTML code is On
Problem PT11 MAC stuck in "Playback Engine" selection reload loop fastermaster Pro Tools 11 3 06-28-2013 04:28 PM
"Factory Promo UB" - "Eventide" - iLok license - What plug-in is this? Intini Pro Tools TDM Systems (Mac) 7 08-31-2012 08:27 PM
"Quick Start has failed" error when launching Pro Tools SE AvidCS Pro Tools SE and Essential (Mac) 1 03-10-2012 01:51 PM
Import session data... please break out "plug in settings" and "plug in automation" yeloocevad Pro Tools TDM Systems (Mac) 19 10-05-2011 01:04 PM
"Buss" and "Plug in" words grayed out... amba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-10-2008 04:23 PM
