spdif out on 003 factory
Hello. I can't seem to get a signal to my monitors using my spdif(rca) output. I understand the digital outputs default to mirror analog out 1&2 and I've selected the correct digital source (rca) in PT I/O setup. My Roland DAW works fine with the monitors, therefore, I think the problem is either the 003, or PT. Any ideas?
PT 7.4 / MacPro Quad / 003 Factory / JBL LSR4328P
MacPro 2.66 Quad OX 10.4.10 - Digi 03 Factory - PTLE 7.4 cs2 |
Re: spdif out on 003 factory
I had the same problem and then i figured it out. Under Setup->I/O in Protools change the Output path main L/R to out 7/8 (SPDIF outs). Also, make sure under Setup->Hardware you have SPDIF selected.
Regards, Mike |
I think Albee is right (I wish those would still mirror as the 001 did though ).
As alluded to, make sure said I/O is selected under setups. I usually just hit "default" for both inputs and outputs under "setups" and that put me in good shape with my I/O configuration(s). Len |
Regarding this (and my rant for the week) why can't this setup I/O configuration be "remembered" and constant from, and when opening sessions, session to session (or when creating a new session? Unless said session is saved with a particular I/O I'm always going into setups I/O -at least on a 002R PT. 7.4) I suppose it has to open with the I/O the session was originally saved with. How annoying. Am I missing something?
Len |
Make a session template. It will hold your settings. It is very handy to start with for every new session. See the first 3-4 accelerated videos on the digi website..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Thanks! I'm going to do that for new sessions. I still wish once I/O parameters are set when, and after, PT is up and running it would open existing/older session with that set I/O. Thanks for the tip though.. kinda spaced that out
Len |
Thanks for the help. After I wrap up my current project, I'll get back on it. I did go back to my docs and found in my "Getting Started Guide" (pg 58) it makes the quote "spdif out channels always mirror the main outs 1-2". I thought I read that somewhere.. I'll double check the routing.
Thanks again
To route a Pro Tools output channel pair to multiple audio interface output ports:
1 Choose Setup > I/O. 2 Click the Output tab. 3 Click the Output selector for an interface channel pair, just below an audio interface icon. 4 From the pop-up menu, select a physical port pair (such as Analog 1–2) to route to the corresponding Pro Tools channel pair (such as A 1–2) in the Path Name column on the left. 5 Start-click (Windows) or Control-click (Mac) the same Output selector and select an additional output pair from the same pop-up menu. The output name updates with a plus sign (“+”) before it to indicate that multiple output ports are selected. In the pop-up menu, each physical port pair assigned to that Pro Tools output pair is indicated by a check mark. 6 Repeat the above steps to select additional output destinations. 7 Click OK to save changes and close the I/O Setup dialog.
ProFire 2626: SPDIF COAX & SPDIF OPTICAL Simultaneous success!!! WHAAAA HAPPENED??? | cueball73 | macOS | 0 | 05-22-2012 12:41 PM |
mono like sound from spdif out (GA-EX58-UD3R) to spdif in (Omni ) | chrisdee | Pro Tools HDX & HD Native Systems (Mac) | 9 | 04-02-2012 05:10 AM |
PT8 & 003 Factory: No SPDIF Output at all | bvcreative | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 117 | 11-13-2010 03:51 PM |
Using Digital Coax (SPDIF) Out on Digi 003 Factory for monitoring? | Belegur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-09-2009 09:36 PM |
Digi 96io - can you mix Optical SPDIF and phono SPDIF? | buckaroo | Pro Tools TDM Systems (Mac) | 1 | 08-24-2009 11:20 AM |
