Drives not appearing in workspace
Hey all,
So I have a partitioned drive (1.5 TB NTFS) I've got 120gB partitioned to be for extra applications because I'm running Windows 7 off an SSD. Pro tools is installed on the SSD and basically I can only see the applications partition (which is the first one if that matters) in workspace and not the other side (which happens to be my sound Library.) If I try to create a session on the sound lib drive it claims it's not a record enabled drive. Is this a Pro Tools problem or a drive problem? I could try reformatting but it took an entire day to get the damn thing set up in the first place, so I'm trying to avoid it. Thanks |
Re: Drives not appearing in workspace
Your best option to get PT working properly is to have separate drives (not partitions).
System drive (with PT installed on it) Record drive for your sessions drive for libraries Do some research here on the DUC to find out what drives folks are using successfully. Spinning drives must be 7200rpm minimum. I know the WD Caviar Black drives are good (stay away from 'Green' Drives).
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Workspace no drives | sanger | Windows | 8 | 12-11-2012 08:23 AM |
Workspace Window Always Appearing | whitetar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-25-2010 09:42 PM |
Anyone else seeing home and net drives appearing in the workspace in 8.0.3 | diamondschwin | Pro Tools TDM Systems (Mac) | 2 | 01-20-2010 09:26 AM |
Disabling drives from Workspace | Halstein | Pro Tools TDM Systems (Mac) | 2 | 11-24-2008 04:33 PM |
Drives not in workspace | Nashville Bass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-21-2005 07:58 AM |
