Old 05-27-2010, 12:33 AM
skip65 skip65 is offline
Default 7.1 PCM Audio to BluRay Disc
Hi
I have been told on a previous thread that it is possible to burn 7.1 uncompressed audio to Bluray disc - no DTS/DD encoding necessary.
My question is does anyone know how I would do this / what burning software I should use?
I would export the 8 mono channels from ProTools LE with CPTK and then....
Hope someone can help
Many thanks
Old 05-27-2010, 01:02 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: 7.1 PCM Audio to BluRay Disc
Either do an internal-layback or bounce to disc and use "multiple mono". It will export how ever many channels are in the source that you're bouncing. I use Compressor (part of the Final Cut Pro bundle) to create my dvd audio files but that's up to 5.1 I believe. I think you'd need some sort of DTS-HD encoding software.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 05-27-2010, 02:28 AM
Thanks Ryan. Apparently bluray can handle 7.1 surround channels without any need for encoding, my surround amp definitely accepts 7.1 PCM audio channels and my bluray player will output it to the amp via HDMI but I'm just not sure which software will give me the option of burning it to the disc like that.
It's also completely possible that i'm way off the mark and have it totally wrong.
Any ideas anyone?
Old 05-27-2010, 02:33 AM
DigiTechSupt's Avatar
I'm unaware of any software that will allow you to do that...yet.
Not saying it isn't out there, I just think I would have come across it if it were...you may be on a fruitless hunt, if my info is correct.
Avid Audio Tech Support
Support FAQ
Old 05-27-2010, 03:06 AM
Ah righto, thanks for that DigiTechSupt.
Ok so would you know the easiest way of encoding DTS or DD from ProTools LE with CPTK?
I'm guessing an expensive plugin purchase is necessary...hope not though!
Thanks
Old 05-27-2010, 03:11 AM
Ryan Young's Avatar
http://store.dts.com/
It depends on what you call "expensive"
DTS-HD is a lossless format, btw. "bit for bit identical to the studio master"
-Ryan Young
Additional Systems
Old 05-27-2010, 03:14 AM
Check out the Minnetonka Audio products - they have some reasonably priced solutions...
Support FAQ
Old 05-27-2010, 03:27 AM
Ryan Young's Avatar
NICE FIND!
-Ryan Young
Additional Systems
Old 05-27-2010, 04:52 AM
Thanks for the help guys. It seems the only option is this: http://www.hhb.co.uk/hhb/uk/products/detail.asp?ID=2382 but it's over £1000. I was hoping for something a lot cheaper.
The Minnetonka stufff seems to be for compressor only (i'm on a PC) and any other encoders only seem to do 6.1 max.
Any ideas?
Old 05-27-2010, 07:10 AM
hummerZ hummerZ is offline
You would need access to a legit blu-ray authoring system. Blu-print, Scenarist, maybe even DoStudio, to put PCM on a blu-ray disc (which is possible).
You could also utilize the DTS or Dolby options, but even if you managed to encode them, you'd still need an authoring system to get the encodes onto a disc.
And.. DTS-HD is not lossless. DTS-HD/MA is lossless.
HTML code is On
Compatible LD DVD/Bluray drives for Mac Pro Alécio Costa Pro Tools TDM Systems (Mac) 0 04-10-2013 06:23 PM
New Dolby Lossless Upmix for Bluray dr sound Post - Surround - Video 4 05-23-2012 10:36 AM
BluRay in NYC stormmusic Post - Surround - Video 9 08-30-2010 09:04 PM
.DTS-HD to bluray? skip65 Post - Surround - Video 7 08-25-2010 02:36 AM
7.1 with CPTK to bluray skip65 Post - Surround - Video 5 05-21-2010 04:13 AM
