Session Sample-rate conversion
I would like to know how to go about converting my session from 44.1 Khz to 48Khz reliably and with no timing issues. Would appreciate an immediate response if it is at all possible.
Re: Session Sample-rate conversion
I can give you two suggestions. Depending on how urgent the situation is you could perchase something like a Z-Systems sample rate converter. Or if perhaps you are working with PT's under Windows NT you could perchase a very handy and versitile software called "Soundforge" from Sonic Foundry. Soundforge will allow you to convert the sample rate from 44.1 to 48 then you would import the file back into your PT's system.
macguy |
Import session data sample rate conversion also stetches audio? | nick133 | Windows | 1 | 07-18-2012 10:30 AM |
Sample rate conversion | HD2 | General Discussion | 1 | 11-19-2010 04:09 PM |
Sample rate conversion within PT | Ruben_B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-25-2005 08:11 AM |
session sample rate conversion | drz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-30-2003 10:57 AM |
sample rate conversion | dj buttnaked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 06-06-2002 03:17 PM |
