Bouncing PTLE sessions to .wav file help!
I can bounce to audio....no problemo....I tried to do the same w/.wav unsucessfully. Can someone please help!
Re: Bouncing PTLE sessions to .wav file help!
Somebody please! I have checked the manual and could not find anything. Help!
You could bounce to aiff or sound designer II and then convert the file to wave format in another application.
soundApp is a good sample converter. It's free too. I'm assuming it's an issue with protools' way of handling wave files that make bouncing directly to wave a problem. I always use sd2 or aiff format myself so I've never noticed. |
If you're not doing so, choose the "Convert after bounce" in the bounce dialog window. This should reduce the load on CPU during the bounce as WAV is not really "as native" as AIFF on Mac.
Ok, I am a little confused [img]images/icons/confused.gif[/img] What I attempted to do was bounce a session to disk as usual except instead of using SDII I selected .wav. It all seemed to work fine when I did it...I created a folder for .wav files and bounced a few sessions. I then tried to drag & drop the .wav files to itunes to burn to disk(probably where I went wrong) but itunes would not accept the files. This all new to me so please excuse my ignorance....please help!
Why would you make .wav files for itunes?
No need. IT sounds like PRo tools did what you asked it to do. Itunes seemed to drop the ball. |
Blazin -
It might help us if we understood why you are bouncing first to .WAV ? The only reason I can think of is compatibility between your Mac and a PC. If in fact you have no reason to go to PC with any of this "audio data", then stay in the formats that are "native" to Mac. Ie. - .AIFF - Native raw audio format for Mac .SDII - Native to PTLE (from Sound Designer days, its an older app from Digidesign, pre Pro Tools) .WAV - Native raw audio format for PC(wintel). This is the Microsoft equivalent to .AIFF. Hope that helps, if not, explain why you need to bounce first to .WAV, and then burn to CD via iTunes. Best Regards,
Dan Atkins The Electric Trombone Studio |
[QUOTE]Originally posted by The Electric Trombone:
[QB]Blazin - It might help us if we understood why you are bouncing first to .WAV ? The only reason I can think of is compatibility between your Mac and a PC. If in fact you have no reason to go to PC with any of this "audio data", then stay in the formats that are "native" to Mac. Ie. - .AIFF - Native raw audio format for Mac .SDII - Native to PTLE (from Sound Designer days, its an older app from Digidesign, pre Pro Tools) .WAV - Native raw audio format for PC(wintel). This is the Microsoft equivalent to .AIFF. Hope that helps, if not, explain why you need to bounce first to .WAV, and then burn to CD via iTunes. You got it....I am bouncing to .wav to use my trax in a friends PC where they would like to do the vocals. I am approaching this bassackwards? |
FWIW it's important to realize that .wav is now the standard file format for all professional audio applications on ALL platforms.
AIFF and SD-II support will probably be around on the Mac for a few more years but when we hand an audio file off to somebody else in the future, they'll be expecting to see a .wav that they can load into ANY system.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
Can newer PTLE always process older PTLE sessions? | Earl D | Windows | 3 | 02-25-2014 12:02 PM |
delay bouncing midi file to wav. file | alessio | MIDI | 7 | 09-09-2009 08:07 PM |
Bouncing Pro Tools sessions | mejolt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-09-2007 05:41 PM |
invalid PTLE 6.4, required dll file,File.dll not found | martinleys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-13-2007 09:41 PM |
Txfr PTLE 5.1 Session FIles to PTLE 7.3 Sessions | MITD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-23-2007 05:22 PM |
