Old 12-08-2022, 10:09 AM
Blues Bird Blues Bird is offline
Default PT Ultimate - one licence - two machines?
My PT Ultimate runs on my studio Mac with an ilok.
Can I transfer the PT licence from the iLok to the iLok cloud and then use PT either on my studio MAc or on my Macbook Pro?
Thanks for your help.
Old 12-08-2022, 10:17 AM
Default Re: PT Ultimate - one licence -two machines?
Sure in principle, but the moment you have any network connectivity problem Pro Tools stops working. I would trust a physical iLok over iLok cloud any day. Switch that iLok between systems if needed.
Old 12-08-2022, 10:27 AM
JCBigler's Avatar
JCBigler JCBigler is offline
Being able to move to different computers with the same license, it literally the whole reason that iLok was invented in the first place.
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB
2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio
Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
Old 12-08-2022, 10:58 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
I've used iLock cloud for working between my PC and my Mac.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Ben Jenssen's Avatar
Right.
iLok Cloud is only a viable option if you have a very reliable internet connection on both locations. The second the signal fails, PT will not work. In case you go for that option, this is how it works, in short; you move the license from the iLok key to iLok Cloud. When you need to use PT on the other machine, you do it with a couple of clicks in iLok License Manager, and the license will start working on that mac and stop working on the other. You don't have remember to 'disable' it on the other mac.
But I can't see why you don't just bring the iLok with you.
Another option could be second license. Depends on what you want to use PT on the laptop for. A PT Artist license is on sale now for $80 for one year.
I hear you, but it sucks big time to have to fiddle with the iLok between two computers on a regular basis.
Old 12-08-2022, 01:05 PM
sw rec sw rec is offline
“ I hear you, but it sucks big time to have to fiddle with the iLok between two computers on a regular basis.”
Maybe, but it sucks even more to have your work grind to a halt if/when the ‘net goes down.
Old 12-08-2022, 09:39 PM
Obsidian Dragon Obsidian Dragon is online now
Or when the iLok servers go down or is under going maintenance. There have been times that everyone using cloud based iLok could not use Protools. There is a time and place to use cloud based iLok. I just would not do it if I had paying clients or deadlines to meet. I'm not sure why it "sucks big time." Unplug iLok...Bring with me...Plug in iLok. I do that all the time.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 12-08-2022, 10:07 PM
jeffro's Avatar
jeffro jeffro is offline
Originally Posted by Darryl Ramm View Post
...the moment you have any network connectivity problem Pro Tools stops working...
Originally Posted by Ben Jenssen View Post
...The second the signal fails, PT will not work...
A bit of clarification if I may...
Pro Tools does not immediately just stop working if using iLok Cloud and your internet connection gets interrupted. There is a grace period that allows you to continue running, and after a period of time PT will alert you about the interruption so you can correct it - but PT continues to run. A short time later you'll be presented with a dialog that allows the opportunity to Save before quitting so you could then correct the issue (reconnect your internet, or move your license to an iLok using an internet connected machine).
If you have an iLok USB key you might be best served using that, but iLok Cloud is convenient if moving between machines often, or working in an environment where you don't want to leave your iLok USB key with all your licenses exposed.
Use whichever option best suits your needs.
linkedin
Old 12-08-2022, 11:39 PM
JCBigler's Avatar
I work with Protools on two different computers at the same time, both of them running in redundant mode with Satellite Link. That means I have two Protools licenses on two different iLoks, and also keep two pare iLoks. I carry them in a small folder that also carries the rest of my USB flash drives. My computers are never connected to the internet while recording with Protools, so the iLok cloud thing wouldn't work for me.
I guess it's just the way I'm used to working, since I've always used Protools with an iLok since 2003. I've had my rage against iLok and Avid and iLok finally won out and I gave up and accepted it. It is actually the most convenient method of securing Protools licenses.
Justice C. Bigler
Protools Perpetual Education licence to Full licence conversion WestGoose Licensing & Accounts 5 08-23-2023 11:56 AM
Switch EDU Perpetual Licence to subscription non-education licence Theo_Lacombe Licensing & Accounts 1 09-17-2021 01:13 PM
Pro-tools Ultimate perpetual licence The golfer Buy & Sell 2 12-16-2019 06:29 PM
Probleme de licence PT Ultimate [Résolu] Eurodvd Le Forum en Français 3 09-03-2019 11:32 AM
