Old 10-03-2022, 02:07 PM
JingleDjango JingleDjango is offline
Default Some Melodyne track data can't be found. Melodyne edits on affected tracks may not pl
Melodyne 5 (ARA2 editor) opens with the following prompt:
The document loaded was corrupted and has been repaired automatically. For safety, please check your edits."
Not sure what I did to trigger this. I'm afraid to use ARA any more.
macOS 12.5.1
PT 2022.9
Old 10-03-2022, 07:39 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default Re: Some Melodyne track data can't be found. Melodyne edits on affected tracks may no
macOS 12.5.1
PT 2022.9
You didn't do anything. It comes with the new territory. I believe this message only comes in an older session with ARA edits in 22.9. In my case, it was harmless. ARA is cool, just needs to be refined a little.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 11-24-2022, 05:59 AM
Actionmusic Actionmusic is offline
I'm seeing this quite a bit, todays reopening of yesterdays session has 11 "Some Melodyne track data can't be found" errors, and obvious to my ears much of the days tuning work has disappeared. 12.5.1 2022.10 , anyone point me to any troubleshooting that people have done looking into this?
I haven't had time to troubleshoot - seems to be on mostly large sessions (although those are generally what I run), also noticed once the PT loading message and the Melodyne window "corrupt data" message have appeared even if I retune some notes , then resave as another session and open again, even those new tunings will not have been recalled. frustrating!
Old 11-24-2022, 07:20 AM
Can't help you. I gave ARA2 a pass after encountering too many issues. I don't feel I can rely on it for critical work yet.
Old 11-29-2022, 10:24 AM
strawb strawb is offline
same issue here.. just lost a ton of tuning/timing work and now i dont trust the rest of the tracks that seem to be playing ok. unreal. this is super un-pro (tools). got no work around except to do it again and then immediate commit the MD work.
Old 12-02-2022, 07:47 AM
Rica Rica is offline
2 days of work gone to trash. I've got a prompt saying that Melodyne was recovered and suggesting me to check my work. Really? I had 26 tracks with Melodyne, hundreds of clips. So I bounced the session, flipped the phase and summed to a bounce made just before closing the session yesterday and voila, TOTAL RANDOM MESS. Its like it takes life at night and messes your work for you.
This is so frustrating, and now I can't trust any of the other sessions I have Melodyne on. From what I've seen all of them are opening with corruption errors.
At least they should have called it a beta version with some disclaimers. That would have saved a ton of work.
Thank you Celemony, and have a great weekend because I just lost mine...
Old 12-02-2022, 08:02 AM
Carl Lie Carl Lie is offline
The Melodyne plugin works fine. I prefer it to the way ARA has been integrated. Especially the window size.
Not sure it's Celemony's fault the integration in PT isn't working well yet.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 12-03-2022, 04:23 AM
midnightrambler midnightrambler is offline
Just FYI Melodyne never cancels when you ø , it’s not and never has been sample accurate. I tend to think of it operating more like a MIDI instrument in that regard.
Old 12-03-2022, 04:40 AM
Dax Productions Dax Productions is offline
I’ve had TONS of issues that made me give up for now on ARA melodyne. Back to using the plugin.
Really feels like we’re beta testing this for them. Would have been nice if they could have let us know that, so that I could have a avoided a few instances of lost time/money having to re-do a few projects in the last month.
Old 12-03-2022, 09:44 AM
psycho's Avatar
psycho psycho is offline
I too had problems like these.
In my case I found the reason for the mess.
Take a look here: https://duc.avid.com/showthread.php?t=422686
Hopefully the Pro Tools team will fix this soon...
PT Ultimate 2022.12, HD-Native PCIe, 4x 192 I/O, Sync HD, MIDI IO, 2x Pre, 40 Channel Icon D-Command, X-Mon
PC: Windows 10 Pro, Intel i7-10700KF, 32 GB DDR4 3200 RAM, MSI MEG Z490 Ace, Nvidia GTX 950
Notebook: Windows 11 Pro, i7-1165G7, 16 GB RAM, 2 TB SSD
"Some Melodyne track data can't be found." Error swfeathers Pro Tools 5 09-30-2022 10:28 PM
Alternative to Melodyne for Audio to MIDI? Or Which Melodyne version? DBK Getting Started 6 12-15-2014 11:33 AM
Fast way to print Melodyne's Edits to Audio Dizzi45Z Tips & Tricks 13 11-07-2013 05:23 PM
Melodyne Users - Melodyne Editor Beta release imminent! Driven01 Pro Tools M-Powered (Mac) 2 09-18-2009 06:31 AM
Melodyne Users - Melodyne Editor Beta release imminent! Driven01 Pro Tools M-Powered (Win) 2 09-18-2009 12:15 AM
