Old 10-24-2011, 12:43 AM
soundworx soundworx is offline
Default HDX vs HD2 power now and come 64 bit
If one HDX card is 5(?) times as powerful as a PCI-e accell card, what would be the comparison between a one card HDX system and my HD2? 2 to 2.5 times more power?
But if 11 goes 64 bit, doesn't that mean it has to do more calculations thus reducing that difference to.... what? I don't want to upgrade and come to the conclusion I need another card to get comparable performance in the future.
Old 10-24-2011, 01:08 AM
BasketCase BasketCase is offline
Default Re: HDX vs HD2 power now and come 64 bit
No, it is the other way around. A 32bit system can only process data in 32bit long strings. A 64bit system can process double the amount of data of a 32bit system in the same time.
I am not sure how AVID are calculating the speed of those HDx cards. If they are operating at 32bit internally on 64bit processors then we may very well see a performance increase come protools 11.
Old 10-24-2011, 09:17 AM
bad jitter bad jitter is offline
That's a very good question. I believe HDX has about 2,5 rimes the power of HD2 Accel. But on 64 bit, does it have only 1,25 times the power, so it's very much like HD2 is today. Maybe AVID could chime in?
Old 10-24-2011, 09:22 AM
TOM@METRO's Avatar
Another question (if we are looking to the future) would be; how will this compare to the next generation of Native processing? Intel is not standing still either.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 10-24-2011, 09:29 AM
Emcha_audio's Avatar
Since HDX shares processing power with the host (able to use the card and the host) performances could be seen to be much higher than just 5 times. And not to mention that the dsp chips on the hd cards were not 32 bit word length but 24 bit word length. That means it's even more powerful now than the hd accel system.
Pt HDX 1 is more powerful than a hd 3 system that says a lot already. Some say it's even more powerful than hd 4 and 5.
The faster the host will be the faster the HDX card will be, to a limit of course.
Manny.
Wave-T.com
Old 10-24-2011, 09:45 AM
mike connelly mike connelly is offline
Generally, 64 bit is the same or a bit more efficient than the same app in 32 bit. Before other audio apps released 64 bit versions, some people mistakenly assumed things like performance getting cut in half but that wasn't the case at all. It's not 64 bit audio we're talking about, it's the code and the CPU - a better comparison is like a road getting upgraded from 4 lanes to 8 lanes, it lets it move the data around faster.
Old 10-24-2011, 11:46 AM
Cloud_9 Cloud_9 is offline
Very relevant question,
PT11, Windows 10
RME Babyface
Old 10-24-2011, 12:06 PM
PaulV's Avatar
PaulV PaulV is offline
HDX has the same audio processing power whether the Pro Tools software is built as a 32 bit application or 64 bit application, and its capacity won't change when a 64 bit Pro Tools is released.
In the simplest terms, a 64-bit application runs almost the same as a 32-bit application, except for the amount of memory it can use. The main reason for wanting a 64-bit Pro Tools application is for using more memory, such as happens with really big virtual instrument plug-ins, or in rare cases, with giant post-production sessions with hundreds of tracks and hours of audio. Running as a 64 bit process doesn't usually change the performance of the application.
It's perhaps confusing because we use "32 bit" and "64 bit" to refer to different things. A 32-bit application is independent from using 32-bit audio. Pro Tools uses 32 bit audio, and will continue to do so once a 64 bit version of the application is released.
Hopefully that helps clarify it.
Cheers,
Paul Vercellotti
Avid Engineering
Old 10-24-2011, 12:40 PM
drumster drumster is offline
Thanks for weighing in Paul! We appreciate your presence on the forum.
Lynx Hilo Thunderbolt
2013 Retina Macbook Pro 2.7 16 GB of RAM
PTHD 11.3.1 OSX 10.10.1
Would this UPS (Uninterrupted Power Supply) protect and power my gear? D_Japan macOS 4 07-24-2011 04:23 PM
002R Faults + power harness + no phantom power DaveSB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-26-2009 01:10 AM
Correct Order to Power Up & Power Down Digi 002 Rack? bilco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-12-2008 06:57 AM
Mbox 2 power consumption? How much of a power load is this spaids 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-30-2007 06:27 AM
002 rack power harness power suplly issue rockstah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-06-2004 11:04 PM
