gluing the fader caps on...
Has anyone succesfully done this?
Anything I should know about conductivity of the caps? Any specific are that I should not apply glue? Every other time the unit banks, faders pop off and fly all over the place |
Re: gluing the fader caps on...
I just took a tiny amount of cottonwool and put around the insides - and it has worked. See earlier posts about this problem.
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8, Digi002 Fact., Logic X|FCPX|Motion Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix |
Support has given me a very helpful tip. If you look under the cap there are two notches. make sure they are on the left side, otherwise they will be loose. I flipped all of mine around and it makes for a much more snug fit. I can't believe it was that simple. |
oh sweet thanks robert
all of mine were backwards!! problem solved |
http://www.youtube.com/c/wizprodux |
On my two latest units all had to be turned around - didn't see the small knobs before (and it seems like the assembly line missed it as well...). Thanks for solution.
003 fader caps. set of 8 | albee1952 | Buy & Sell | 3 | 10-09-2012 04:01 PM |
Proper fader caps for 002/003: Here! | Gary Nattrass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-30-2011 05:35 AM |
002 Fader Caps.... | flarocks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-17-2008 08:27 PM |
Command 8 Fader Caps | milkojnr | ProControl, Control|24, Command|8 | 5 | 08-08-2008 11:47 AM |
Fader caps | jalpunk | ProControl, Control|24, Command|8 | 8 | 03-13-2005 03:58 PM |
