Old 11-27-2009, 03:57 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Default OT: Divergence in Center Chan Dialogue?
I finally got a chance to sit down and watch NCIS Wednesday night (DVR'd) on my surround system, which brought up some questions. I'm sure there will be as many opinions as users...
I love dialogue in CENTER as opposed to phantom, yet I usually have about 20% divergence from center spilling into LEFT/RIGHT just to widen the 'hole' a bit. This is easy to do on the SSL C200 we have, as divergence is adjustable from -100% through 0 to +100% (clockwise). From 0 to -100% removes signal from Center and adds to L/R, keeping the overall SUMMED level the same (especially on the downmix). From 0 to +100% adds to L/R keeping Center at full volume, adding to the summed level in the downmix.
Since I run +20% typically I compensate in the Dolby downmix by dropping CENTER channel metadata from -3dB to -4.5dB. This works great for my stuff.
SO back to NCIS... it sounded like there was some divergence in the dialogue, pretty close to +20%. I should've switched back-n-forth between 5.1 and LtRt, but that would've put the wife over the edge a little too quickly.
SO (1) what are most of you TV mixers doing and (2) do you compensate at all in the metadata for Dolby?
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
HTML code is On
5.1 Mix Narrator Center channel Dialogue Centre or phantom Center? kd_special Post - Surround - Video 5 03-02-2011 02:53 AM
5.1 Film Mix Issues - Divergence - Center Channel Audiobotica Post - Surround - Video 11 12-25-2010 04:28 PM
Using divergence to get material into the center CD Productions Post - Surround - Video 6 10-27-2005 03:30 AM
Divergence question citysoundman Post - Surround - Video 6 09-10-2003 06:28 AM
Divergence John@Fusion Post - Surround - Video 2 05-07-2003 09:41 AM
