distorted imported audio
Hi there,
I have a problem with importing audio. After I import a song (WAV) and play it back it is distorted and doesn't sound like it should (i.e. instrumental tracks lacking certain components) Has anyone had this problem. I'm new to pro tools so i hope there is a quick fix. By the way my specs are: Pro Tools LE 7.4 Mbox 2 Toshiba Laptop Windows XP Home Edition Version 5.1.2600 SP2 Build 2600 Intel Perntium M Processor 1.60Ghz Let me know if you can help Thanks |
Re: distorted imported audio
What are you importing from - cd, dvd, your hard drive, etc? What format are the original files in? Where did they come from? Do they play back properly in another application, like iTunes, Quicktime or Windows Media Player?
Thanks for the reply. The files i'm importing are WAVs (bit rate: 1411kbps, audio sample size: 16 bit, stereo, audio sample rate: 44khz, audio format: pcm) from my hard drive that have been copied from CD. Yes, they all playback fine in other applications Here is my laptop spec: Processor Model : Intel(R) Pentium(R) M processor 1.60GHz Speed : 1.60GHz Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile Internal Data Cache : 32kB, Synchronous, Write-Back, 8-way, 64 byte line size L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 lines per sector System System : TOSHIBA EQUIUM M40X Platform Compliance : Intel Centrino Mobile Technology Mainboard : TOSHIBA EAL30 Bus(es) : PCI IMB PCMCIA CardBus USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes System BIOS : TOSHIBA V1.60 Total Memory : 504MB DDR SO-DIMM Chipset Model : Toshiba 82915PM/GM/GMS, 82910GML Host Bridge Front Side Bus Speed : 4x 133MHz (532MHz) Total Memory : 512MB DDR SO-DIMM Shared Memory : 8MB Memory Bus Speed : 2x 166MHz (332MHz) Video System Adapter : Mobile Intel(R) 915GM/GMS,910GML Express Chipset Family (128MB, PCI, PS2.0) Storage Devices HTS541060G9AT00 60GB (ATA100, 2.5", 5400rpm, 7MB Cache) : 56GB (C:) MAT[bleep][bleep][bleep][bleep]A DVD-RAM UJ-831S (ATA33, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices Hard Disk (C:) : 56GB (NTFS) @ HTS541060G9AT00 60GB (ATA100, 2.5", 5400rpm, 7MB Cache) CD-ROM/DVD (D:) : N/A @ MAT[bleep][bleep][bleep][bleep]A DVD-RAM UJ-831S (ATA33, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Toshiba 82801FBM (ICH6M) LPC Interface Bridge Audio Device : Toshiba 82801FB (ICH6) AC'97 Audio Controller Audio Codec : Realtek Semiconductor 0052h Audio Codec : 494Ch 0027h Serial Port(s) : 1 Disk Controller : Toshiba 82801FBM (ICH6M) SATA Controller USB Controller 1 : Toshiba 82801FB (ICH6) USB UHCI Controller 1 USB Controller 2 : Toshiba 82801FB (ICH6) USB UHCI Controller 2 USB Controller 3 : Toshiba 82801FB (ICH6) USB UHCI Controller 3 USB Controller 4 : Toshiba 82801FB (ICH6) USB UHCI Controller 4 USB Controller 5 : Toshiba 82801FB (ICH6) USB 2.0 EHCI Controller FireWire/1394 Controller 1 : Toshiba OHCI Compliant IEEE-1394 FireWire Controller CardBus/PCMCIA Controller 1 : TI PCIxx21/x515 Cardbus Controller System SMBus Controller 1 : Intel 801xx/63xx SMBus Network Services Network Adapter : Realtek RTL8139/810x Family Fast Ethernet NIC - Packet Scheduler Miniport Network Adapter : Intel(R) PRO/Wireless 2200BG Network Connection - Packet Scheduler Miniport (Ethernet, 36Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 97% Operating System(s) Windows System : Microsoft Windows XP (2002) Home 5.01.2600 (Service Pack 2) Platform Compliance : x86 any more help would be great. if you need anymore info let me know. thanks |
Need some more info from you;
Along with spkguitar's questions, there's a few things I wanted to comment about. First, you have well below the minimum RAM requirements for 7.4:
Also, you only have a single hard drive: Quote:
I don't necessarily think either of these are a factor in the problem you're having, but you should know about them to avoid further problems. |
Hi all, thanks for all the help and advice.
I finally had to time to mess around with my mbox 2 today to see if i could fix the problem and i did! In the end it was an easy fix - i changed the output on the track from output 1-2 to mono. This helped yet i don't fully understand why. Just one more thing, if i buy an external hard drive with "at least an Oxford 911 chipset and 7200rpm" e.g. GT050Q) and upgrade my RAM will this avoid any other problems you foresee? thanks again for the help with my 'noobie' problems |
44.1 or 48 if audio is imported? | audiofreak11 | Pro Tools 10 | 9 | 06-05-2013 08:33 PM |
Imported Audio Out Of Time | goosefreak | Pro Tools M-Powered (Mac) | 0 | 10-12-2012 07:40 PM |
Audio Handles / OMF imported | pmourard | Post - Surround - Video | 1 | 10-09-2010 01:00 AM |
imported audio is distorted | mixit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-19-2004 08:45 PM |
Imported Audio Syncing??? | ronev | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-29-2003 12:57 AM |
