MINOR DELAY WHILE RECORDING WITH MIDI
HI,
I NEED HELP!....i have the 002 mixer with my Triton keyboard connected to it, when i record into pro tool there is some sort of delay that throws the whole track off and it makes it hard to edit the track....AM I BEING CLEAR ENUFF?.....can anybody help me with this?...Could it be the cables?....I Have a PC thank you |
Re: MINOR DELAY WHILE RECORDING WITH MIDI
Unfortunately, you're not being clear enough.
Most likely you're having a problem with latency, though I can't be sure from the minimal amount of info you've posted. I just dug up a quickie article on latency that may help you understand it better and determine if that's the problem you're having. Usually reducing your HW buffer size will take care of it. If that's not the case, please explain in a little more detail your exact process and where the problem is occurring. |
i know what you mean. im always having to nudge my hardware audio back to line up with my softsynth audio tracks. it really sucks.
I posted this in the HD forum. might help you guys.
Try this: Record the audio output of the midi to an audio track... the first 10 seconds will do. change the main clock to SAMPLES zoom in to sample level on the newly recorded audio Make a selection from that first sample of the recorded audio BACKWARDS toward where the audio SHOULD start ie: the start of the session Now the main clock should have start/end/length Write down the length value. open the midi offest window and enter the NEGATIVE length value for that midi track. That should line it up give or take a few samples, as the latency is never perfectly the same. hope that helps, I could explain it better if I was sitting in front of my daw but I'm not at the moment. -Joe
Joe Fitz Producer / Engineer |
does this work with instument tracks???
ill try that ...thanxxxxxx
MIDI timing / recording delays with Delay Compensation | DAWgEAR | Pro Tools 10 | 23 | 03-08-2020 06:12 AM |
Trigger to midi delay vs Microphone lack of delay | DrumEatDrum | The Drum Room | 2 | 04-12-2010 08:45 PM |
Delay when recording midi tracks | Kyle Weir | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-15-2007 10:09 PM |
midi delay when recording from sampletank | crb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-23-2005 10:51 AM |
Does this bug you? (minor midi annoyance) | Dopamine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-30-2004 03:50 AM |
