SIgnal ROuting
I just recently got Pro-Tools. However I am not new to it, I have used it before. I am running LE on an iBook. THe operating system is Tiger. I am having some problems signal routing. I am trying to use an aux track as a sum track. I am setting all of my individual track outputs to the same bus that is the input for the aux tack. I have made sure that nothing is muted and all of that stuff. I havn't even been able to get signal to an aux track using it as a send. Is this a known problem or am I mising something completely. Again, I have made sure that the volume on the send is turned up and nothing is muted. Thanks.
Re: SIgnal ROuting
What is the output for the aux channel? Set it to your main outs for starters. There is no problem with this setup, it's integral to mixing, creating submixes and such. You're missing something.
One thing I don't like about PT is that if you solo an aux send that is serving as a submix for several channels, nothing comes out. To me, it would be logical that all the instruments going to that aux send should be solo'd. Instead you have to solo the aux send AND each channel. Keep fiddling with it. |
Re: SIgnal ROuting
Re: SIgnal ROuting
... however, your tip could still be applied, by applying solo-safe to *all* the tracks feeding the aux. Cool. Cheers.
SoundPunk | Pro Tools Tips & Tricks |
Re: SIgnal ROuting
Technically you're right, but that's not very practical. If you have audio tracks solo safed then they won't mute as you'd want them to when you solo another track. Then, any pre or post fader sends you have feeding reverbs would still be receiving signal from the track which would cause the infamous "ghosting" sound of tracks you wanted to go away when you soloed something else.
As for the original poster's question, I'm not really sure what he's missing because he seems fairly sure about what he's doing. He's apparently missing SOMETHING because what he's describing is something I do about 100 times a day, so there's no issue. So in an effort to help him out, here's what I'd advise: 1. Take all of your audio tracks and assign them to the main outputs and verify that you can hear them properly when assigned that way. 2. After you've verified that everything is playing from step 1, create a stereo aux input track. I usually put a sub-group master like this adjacent to the tracks that are feeding it, but that's not a requirement to get it to work. 3. Assign the input of the aux track to an available pair of busses. Make sure this track's fader is set to unity gain (0.0dB) to start with. Also make sure it's not muted and that its assigned to the main output. You may choose to follow my advise above on solo safing the aux track too 4. Now on the output of the audio tracks you want to sub-group down, assign their outputs to that same set of busses. (for example, if you assigned the input of the aux track to bus 9-10, you'll assign the outputs of the audio tracks to bus 9-10) 5. Give it a try. The use of the term "using it as a send" is probably due to a lack of experience and understanding that an aux track is only related to a send when it's used as a return track for an additive effect. The type of configuration he was describing is where the signal is being re-routed thru a fader where you'll have control authority over the summed volume of the tracks feeding the aux and the ability to effect the whole blend as a group rather than one track at a time. In this type of configuration, the sends don't come into play usually. I hope this helps the original poster workout whatever issue he's having. |
Re: SIgnal ROuting
Re: SIgnal ROuting
why not send them out a send/bus instead of the channel output
or am I missing something |
Re: SIgnal ROuting
Great answer Shawn - well done. You should write the manual for Protools! ...or set up a helpline for Protools tragics!
002R, PTLE 7.3, P'book G4, 1.5Ghz, OSX 10.4, 1 Gig Ram |
Re: SIgnal ROuting
Signal Routing | Jel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-20-2009 07:32 PM |
Signal Routing... | krtshadow | Tips & Tricks | 5 | 03-25-2008 06:55 PM |
Signal Routing | patrick_ny | Pro Tools M-Powered (Win) | 1 | 06-12-2006 07:41 AM |
C24 Signal Routing | 1destiny | ICON & C|24 | 1 | 04-19-2006 12:35 PM |
SIGNAL ROUTING | cigam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-20-2004 11:53 AM |
