ReVibe install problems from MassivePack 4
I recently purchased MassivePack4 and everything installed correctly with the exception of ReVibe. I was able to recreate this problem on more than 1 system.
When trying to install the software, I get the following message in the dialog box: Error creating folder. 1008:9,-5000 Access denied error Any help in this would be greatly appreciated. G5 1.8GHz single OS 10.3.8 2.25 GB RAM HD3|XL 192 I/O PT 6.9
John Wilkinson III johnfwilkinson AT comcast DOT net |
Re: ReVibe install problems from MassivePack 4
-5000 is an OSX permissions problem namely lack of permission
you are logged in under the root admin account? you have repaired permissions w/ Apple Disk Utility? check the permissions of were you are installing w/ Get Info. you need to have read/wright
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Lee Blaske |
I had this problem - fixing permissions of the plug-ins folder should do it. Go to library/application support/digidesign/plug-ins and use command-i to get info on the plug-ins folder. Under "ownership and permissions", set to allow "read and write" for you (the user), select "apply to enclosed items". Install should be fine after that.
Best...H |
Thanks to everyone for the responses.
I had already repaired the disk permissions, and totally spaced out on checking the permissions of the plugins folder. I ended up having to go into the Plugins folder and doing the Apple-I (Get Info) and had to change a setting there. It seems a bit odd that the settings worked for all the other plugins and not this one, but it installed correctly. Thanks again. j
Mountain Lion/PT Install/Ilok install problems | alex obradovic | macOS | 7 | 07-14-2013 06:19 PM |
Problems automating Revibe | icenet | Post - Surround - Video | 4 | 03-02-2012 06:28 AM |
problems using unwrap and revibe in same session | Brandonx1 | Post - Surround - Video | 3 | 06-24-2010 01:28 PM |
Help with VSS3 for MassivePack install | Bender412 | Pro Tools TDM Systems (Win) | 0 | 11-05-2009 05:57 PM |
MassivePack 4 - ReVibe the only Accel-only plug? | chuck.dallas | Pro Tools TDM Systems (Mac) | 5 | 08-25-2005 12:43 PM |
