Old 01-10-2009, 07:04 AM
losttimestudios losttimestudios is offline
Default Click question
Can I set my click plugin in PT to count of 1/8th notes as opposed to 1/4 notes and if so how? Thanks.
Old 01-10-2009, 07:12 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Click question
Insert a digirack delay. set to quaver. set mix to 50%
(Turn up the feedback level to annoy the drummer)
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-10-2009, 07:50 AM
studiojimi's Avatar
studiojimi studiojimi is offline
Originally Posted by crizdee View Post
Chris
hey! don't bug the drummer..he has enough pressure
a printed click can be handy sometimes in 7.4 when you want to be in minutes and seconds but still have an eye on the grid lines
and you can double up and stagger a cop of that track for a double up an 8th note apart.
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 01-10-2009, 08:00 AM
BaileyBass BaileyBass is offline
Or just double the tempo. This works great for initial tracking of Drums or other non midi instruments. Then half the tempo to get started editing or overdubbing.
I am going to try Crizdees method next time though as it is simpler, and one cue mix could be quarter notes, while another could be eighths or triplets (for folks who like subdivisions). Cool. SB
Old 01-10-2009, 08:01 AM
docric docric is offline
From the edit window, click on the + sign next to Tempo in the upper left hand section of the screen. That will display a pop-up Tempo window. Then click-and-hold on the qtr. note icon shown IN that pop-up window. It should now display the various options for note resolution (1/8 note being one of them) of the click.
HTH...
-C' ya'
Rick
MacPro 7,1; 16 core OSX 13.5.2
PT 2023.9; Eucon 2023.6
Dock/S1/2x iPad
Old 01-10-2009, 08:08 AM
EvilElfBoy EvilElfBoy is offline
Just click on meter, and change it to whatever resolution (i.e. quarter, half) This way you don't have to double your tempo but the click will double.
AKA - EvilElfHobo
Pro Tools 10 HD Native | Mbox 3 Pro | MacBook Pro 2.3 i5 | OSX 10.7.4
Pro Tools Music & Post Operator V6-8, Instructor, and Expert ICON Mixer Certified.
Multi-Platinum Pro Tools Videos
Old 01-10-2009, 08:32 AM
That is great too. I can only remember playing with an eighth note click a few times (ballads) in 30 years... could have used it more. First clicks I experienced were the drummer playing a cowbell or clave in time with a "wind up" metronome while being recorded.
You can option/1 on the numeric keypad and get the time operations window.. and make the same changes, for the "non mousey" types.
Goes to show that If I don't use a feature once a month.. i forget it. I am an older model with less RAM, and what I have has been chemically compromised.
Old 01-10-2009, 08:41 AM
crizdee's Avatar
HTH...
I've tried this but kept having problems! maybe i didn't set it right somehow?? do you use this method ok? cheers!
Click where? i click on the meter on the left ruler bar on the ruler bar and meter on the transport and no cigar!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-10-2009, 08:44 AM
Stig Eliassen's Avatar
Have the meter ruler visible, double-click the first meter in the session (usually 4/4), and choose click resolution.
Old 01-10-2009, 08:50 AM
Hey Chris,
I'm not in front of my rig, but Elf may be right... it may be the + sign next to the "meter" tab, not the tempo tab. I always get these 2 confused... altering the resolution in one will HALF the click (if original is qtr notes, it'll play back half notes) and the other will double it....
I'll be in the studio in a half-hour or so and I'll check it and get back to ya'....
..but, to answer your Q, "yes", this is BY FAR the simplest way to play an 8th note click (or 16th or whatever ya want) without changing the session info.
-C' ya'
Rick
Dock/S1/2x iPad
Click II Question DarknessNezumi AAX Plug-ins 0 10-03-2013 02:51 AM
click track question synth2themax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-25-2011 10:55 PM
click track question joelcm Tips & Tricks 3 02-12-2006 02:18 PM
A click question sleadley Pro Tools TDM Systems (Mac) 7 10-14-2005 04:04 PM
Click plug-in question... martin310 Pro Tools TDM Systems (Mac) 1 06-18-2004 05:04 AM
