Mbox pro control panel setup for bussing in Protools?
I cant bus from an audio track into another. Anyone know how to configure the control panel I/O for this? I thought it was software return but it doesn't seem to. Im assuming this is a problem associated with the control panel.
Intel 6 Core i7-4930K CPU @ 3.40GHz 32GB DIMM DDR3 G.Skill Samsung SSD 840 EVO WD Black SATA 7200 ASUS SABERTOOTH X79 Windows 7 Ultimate 64 Mbox3 Pro Firewire 400 ProTools 10.3.8 ProTools 11.3.1 https://soundcloud.com/matthewcrowe |
Re: Mbox pro control panel setup for bussing in Protools?
In pro tools go under Setup, then I/O, Then on each tab press the Default button down on the left side of the window, then press ok.
Now in your session, under the send a-j section of a channel click on one free spot, select Bus and you should now see all the available buses. You can do the same with the outputs section of a channel selecting Bus instead of Outputs, useful if your stemming down VI's or other tracks. If this has resolved the issue, can you please edit the title of your thread with [Resolved], this will help us keep track of what has been resolved or not, thanks. |
Purpose of new MBox Control Panel? | Ormond | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-08-2011 06:24 PM |
MBox 2 Pro Control Panel | ThunderKyss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-08-2009 10:17 AM |
MBox 2 Pro Control Panel | t.wolfen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-08-2007 07:30 AM |
I can't setup my control panel | Darrell James | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-15-2003 01:18 PM |
2930 setup and control panel settings | utopian | Storage Subsystems | 1 | 04-24-1999 09:59 AM |
